Torque numbers
Old Aug 15, 2007 | 10:30 AM
Dalej's Avatar
Dalej
Default Torque numbers
I have removed the primary cover and compensator and need the torque numbers for both. I called two harley service guys and got #85 and #210 for the compensator, figure I had better ask here.
Old Aug 15, 2007 | 10:49 AM
Harleypingman's Avatar
Harleypingman
Default RE: Torque numbers
The torque values in my '04 HD Service Manual for Touring models are:
1. Primary chaincase cover allen head socket screws: 84-108 in-lbs.
2. Engine compensating sprocket nut: 150-165 ft-lbs.
Old Aug 15, 2007 | 10:50 AM
flashprez's Avatar
flashprez
Don't know if I am any help, but my manual for 2007 says:
Engine compensating sprocket bolt: 155-165 ft-lbs
Always use new bolt.
If you ride an '04 there may be a difference, and someone will post shortly.
Joe
Old Aug 15, 2007 | 10:51 AM
CndUltra95's Avatar
CndUltra95
Dalej, for my 02 Ultra the values are as follows. primary chain case cover allen head socket screws 84-108inch pounds. For the Engine compensating sprocket nut the torque value is150-165ft-pounds.
This is for an O2 Ultra , hope this of some use to you this morning.
you might wanna save up and get the shop maual for your bike/model as it does have some usefull ino in it.
Rob
Old Aug 15, 2007 | 11:06 AM
Dalej's Avatar
Dalej
Thanks guy for the numbers, I'll be putting it back together this afternoon.
robvg
Mar 26, 2013 07:51 PM
30glock
Dec 17, 2011 08:50 AM
xMPRx
EVO
Sep 25, 2011 02:37 AM
gconklin
15
Jul 2, 2010 07:34 PM
Bentwrench
Jul 29, 2009 07:30 AM
