Should I be using a tuner?
I'm assuming you have an EFI bike, not a carb, correct....???
If so, your 2004 Delphi ECM runs an all open loop tune. That means that the entire tune is based on algorithms derived from the OEM parts put on that engine. You do not have any O2 sensors, so there are no real time adjustments made to the AFR in the cruise portions of your tune...
You have increased the airflow to the engine, without "telling" the ECM you have done that... You will be leaner in all areas of the tune, and could be very lean in the critical areas of the tune (high load/high RPM)...
If you ride easy, you would probably have no issues.... If you are a spirited rider, ride two-up with gear a lot, or "drive it like you stole it"... You will be very lean in areas of the tune and could cause damage to your engine...
This topic is hotly debated... but I always change the tune, when I change the airflow of the engine... on any of my EFI bikes..
In some cases it just makes the bike run better, and in some cases it makes the engine run safer... sometimes a lot safer...
Your choice, but IMHO.... retune the bike...
Good luck with your decision...
