Brake Pedal
Old Aug 15, 2007 | 11:41 PM
gregm's Avatar
gregm
Default Brake Pedal
I'm looking for a narrower brake pedal. When I put my heel on the floor board('05 E glide classic) and my toe on the aftermarket cruise peg, the brake pedal is sticking into my foot's arch forcing my heel onto the edge of the footboard. I've spaced the floorboard out 1/4" and don't want to go more due to ground clearance in tight turns. Does some one make a narrower brake pedal that doesn't cost a mint? I thought about trimming one but don't want to chance losing the rubber pad's grip on the pedal.
Gregm
Old Aug 15, 2007 | 11:46 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Default RE: Brake Pedal
have you looked @ EZ BRAKE???
https://www.hdforums.com/m_1367468/tm.htm
Old Aug 17, 2007 | 07:34 PM
kurtlange's Avatar
kurtlange
remove the rubber brake pad and cut off the part on the brake arm that holds the pad.
drill a hole for a shifter peg.
have the modified arm rechromed.
Old Aug 17, 2007 | 07:56 PM
fishafly's Avatar
fishafly
I took off the big brake lever pad.... Cut the lever (pedal) in half.. right about where that little indention is... And used a brake pad that fits an FXST... Worked like a charm and took about 20 minutes...
Old Aug 17, 2007 | 08:09 PM
gregm's Avatar
gregm
Thanks for all the ideas. I think I'll check out Fishafly's fix.
Gregm
Old Aug 18, 2007 | 08:36 AM
skratch's Avatar
skratch
ORIGINAL: fishafly
how about a close up pic so we can see what it looks like?
Old Aug 18, 2007 | 09:42 AM
bigbrokah's Avatar
bigbrokah
The huge brake pedal has been driving me batsh!t too, a pic would be great!!
Old Aug 19, 2007 | 06:39 PM
precisionworks's Avatar
precisionworks
Old Aug 19, 2007 | 07:27 PM
fishafly's Avatar
fishafly
ORIGINAL: skratch
ORIGINAL: fishafly
Sorry about the quality, I had to take this with my phone...
Old Aug 19, 2007 | 11:46 PM
bigbrokah's Avatar
bigbrokah
Thanks fishafly. What did you use to make the cut? I think I'd be there for a week with a hacksaw....
