04 roadglide
Old Aug 14, 2022 | 12:39 PM
Ericveazey's Avatar
Ericveazey
Stage II
Default 04 roadglide
Good morning fellow touring riders,
ive got an 04 roadglide an I was hit two weeks ago, I’m looking to see what years are compatible for the plastics I need faring and bags and a gas tank. I have access to 09 parts but don’t want to buy them if they will not interchange. Thanks for any advice ride safe
Old Aug 14, 2022 | 12:56 PM
Screamin beagle's Avatar
Screamin beagle
I'm not certain but being that 09 was the frame change just be careful before buying them. I'd have to guess they won't but just a guess. You can go on Ronnie's micro fiche and search each year and see if they have the same part numbers for pieces you're looking at getting
Old Aug 14, 2022 | 01:07 PM
Ericveazey's Avatar
Ericveazey
Stage II
Appreciate your response so their is 09 bags available and a farring im going to grab the bags they are 100 bugs so that’s a steal but the other parts I’ll check out that search information you gave
Old Aug 14, 2022 | 03:44 PM
johndoe297's Avatar
johndoe297
If I'm not mistaken, the bags will fit. The other two I would def do some research and make sure before I pulled the trigger on them.
Old Aug 14, 2022 | 05:01 PM
Rounders's Avatar
Rounders
Go to palce like rons on line parts and look at part numbers. Some will be different based on colors.
2008 was new tank. Not sure what it would take to make that work. But you are replacing tank, might look at what it would take to convert to 6 gallon in general. Not sure if seats still fit.
If you have to comepletely repalce bags, I would look at converting newer style with new latches. But as said, I kinda though theye were the same until 2014. But I am not the one stuck with the wrong bags.
Old Aug 15, 2022 | 08:38 AM
Architect's Avatar
Architect
I would guess bags and fairing would be OK.
Gas tank in '09 is the larger 6 gallon tank, can be made to work but you need to do some fab work.
themdg
Mar 23, 2022 10:54 AM
jjr
May 20, 2011 03:38 PM
takiniteasy09Ultra
Dec 7, 2009 08:10 PM
tfaucett
Aug 18, 2007 05:38 PM
