recall duration
Old Aug 21, 2022 | 12:56 PM
NELS's Avatar
NELS
Default recall duration
Purchased my 2010 RK new and never went to the dealer for brake light switch or brake bleed per recall. Curious if they are still valid or is there a time limit. I'd ask the local dealer but don't know if I'd get a true reply, TIA
Old Aug 21, 2022 | 01:02 PM
kel03's Avatar
kel03
Is your dealer still open and is it still in your zip code so you can go there
Old Aug 21, 2022 | 01:45 PM
johndoe297's Avatar
johndoe297
Well then you have come the right place.
Old Aug 21, 2022 | 01:56 PM
chopper_man's Avatar
chopper_man
Recall is open for life assuming they still make the parts. Harley's owners page will tell you open recalls. https://serviceinfo.harley-davidson....cle/lookupForm
Old Aug 21, 2022 | 09:27 PM
hattitude's Avatar
hattitude
Contact your dealer and have them run your VIN.....
The caveat to brake flush "voluntary recall" is that if while performing the recall brake fluid flush, if your ABS unit should show signs of failure or pending failure, you the customer must foot the bill for the ABS unit replacement.
This has been already agreed to during discussions with the NHTSA.... The MoCo convinced the NHTSA that if the ABS unit fails, it is actually due to improper maintenance by the owner, not their subpar fluid or design......
OOPs, just noticed chopper man posted the other way to see if you have a pending recall....
Old Aug 22, 2022 | 05:33 AM
NELS's Avatar
NELS
Thanks guys, I can go to dealer now knowing the recall is still valid.
First and last dealings with them wern't great..
Old Aug 22, 2022 | 06:07 AM
BuzzCap7's Avatar
BuzzCap7
+1
Old Aug 22, 2022 | 07:03 AM
skratch's Avatar
skratch
the big thing to look out for is tsb's. if you don't get those taken care of while your bike is under warranty, then you're sol. they aren't deemed safety critical so not a true recall.
Old Aug 22, 2022 | 08:31 AM
hattitude's Avatar
hattitude
That's too bad... I have a couple dealers I would't let wash my bike, let alone work on it.... That's why I finally took over all the work on my bikes, other than tires. I use an independent motorcycle tire shop for tires... and I even bring them my wheels...
Any chance there's another dealer almost as close that you can go to.... It really sucks having someone work on your bike that you don't trust...
Good luck with the recalls...
Old Aug 22, 2022 | 09:22 AM
strych9's Avatar
strych9
Safety recalls never expire.
russ33541
2014-2024 Touring Models
May 8, 2023 06:48 PM
Coloradohunter
Jul 2, 2014 04:38 PM
Benway
Dec 15, 2012 08:53 PM
zoozoo
Oct 20, 2011 10:11 PM
locodude
Jul 16, 2011 08:47 PM
