Recommendations for ignition module
Old Aug 31, 2022 | 01:12 PM
Z's Avatar
Z
Default Pulled the trigger on the ThunderMax ECM
So here are the choices I faced.
1. Install aftermarket timing module and keep my stock ECM & Power Commander III. This would give me direct control over timing, but would still require more dyno work to get my bike running properly. I'm done with dyno tuning.
2. Get an aftermarket timing module and convert to a carburetor or Delphi EFI. This would be a time-consuming effort, and probably an expensive one by the time all was said and done considering all the parts that we need to be acquired.
3. Purchase a ThunderMax ECM and get rid of my factory ECM and Power Commander III. I'm still left with a few components of the Magnetti-Morelli fuel injection system that could give me trouble down the road.
I think for the time & dollars involved, the ThunderMax is absolutely the way for me to go. Since I already installed O2 sensor bungs in my pipes, I can have the ThunderMax installed and working within a few hours and be done with it for $1000. I'd have spent that much on a carb conversion by the time all was said and done, and it would have taken me months probably and countless hours searching to get the parts for the task, then the hassle of doing the conversion itself. A Delphi conversion would have cost even more.
I'm very confident this will make my bike run properly for the first time since I had the engine rebuilt, give me better fuel mileage, lower emissions, a smoother running engine, and greater longevity as well.
@hattitude Thanks for the recommendation! I'll post later how this goes. It'll probably take a couple of weeks.
Old Sep 1, 2022 | 11:52 PM
CarlosGGodfrog's Avatar
CarlosGGodfrog
Originally Posted by Z
Thanks for the tip. Do you have carbs or Magneti Morelli fuel injection?
Carb, 51mm CV on a 117 w/ S&S 570s.
Old Oct 16, 2022 | 01:41 PM
Z's Avatar
Z
@hattitude : I wanted to circle back around and thank you for your recommendation to go with ThinderMax. I got it installed for a while now, and for the past few weeks have been trying to tune out some low RPM fuel mixture issues, and with getting the timing curve right for my build. This absolutely the right decision for me. I have another thread where I've been working on timing issues.
LDR
Jun 28, 2019 04:27 PM
Schulte94
Evo Era Parts
Nov 10, 2013 11:38 PM
dvanhorn
Aug 19, 2012 10:40 PM
hdbeggs
Feb 21, 2011 07:29 PM
Booey424
Sep 27, 2007 07:40 PM
