2013 ROAD GLIDE Brake trouble
Old Oct 27, 2022 | 02:05 AM
jyx's Avatar
jyx
Had another chanse of some riding this weekend, and the problem is still there, guess it´s time to start looking for someone who has a ABS diagnostic tool but that have to wait till spring,
Old Oct 27, 2022 | 07:02 AM
chopper_man's Avatar
chopper_man
This hasn't been mentioned, but have you checked the rotor(s) for run-out? A warped rotor will cause the same symptoms.
Old Oct 28, 2022 | 02:20 AM
jyx's Avatar
jyx
new rotors are on and have worked perfecft since i bought the bike
Old Nov 1, 2022 | 08:37 AM
jyx's Avatar
jyx
Originally Posted by tankthebiker
Double banjo fittings on the inlet side and plug the outlet. Stack the two for front and two for rear and it is done. The trick is finding the right bolts to plug the hole. I ended up just going to a hardware store and finding M10x1.0 mm bolts and cut them to length.
Here is what I purchased.
https://www.amazon.com/gp/product/B08P71265C
Something like this ?
Old Nov 1, 2022 | 11:30 AM
tankthebiker's Avatar
tankthebiker
Mine was much simpler and didn't require me to remove the block. I just plugged the outlet of the ABS module and used the double banjo that stacked the inlet and outlet hoses on the other side of the block. I will try and get a photo today.
Originally Posted by jyx
Old Nov 1, 2022 | 12:44 PM
jyx's Avatar
jyx
Yes thank´s a photo would be great, i think when doing it like in the video the ABS-lamp may stay on and if that´s the case there is no way of getting the bike through inspection here in Sweden.
Old May 26, 2023 | 08:17 AM
jyx's Avatar
jyx
update on this old thread, the problem with the front brake not holding preassure is still there, so far i have taken apart the calipers and checked so the pistons can move clearly and changed the piston up on the handlebar, i have to "pump" twice to break every time, the ABS system works but this is getting realy anoying, any other suggestions to look at ?
DBLX
Dec 26, 2023 08:21 AM
Glenn Gorman
2018+ Softail Models
22
Jun 26, 2022 06:00 PM
ssgmac11b
Sep 18, 2019 01:00 PM
Ducky111
Nov 23, 2018 05:46 PM
Cornel
Jul 10, 2015 09:59 AM
