I never noticed...
Old Aug 17, 2007 | 09:48 PM
dirtdobber's Avatar
dirtdobber
Default I never noticed...
We have had way above temps.; 100+ degrees. I have been getting around 44 mpg and every once and a while around 46-47. It rained this evening and I went for a ride to enjoy the cool air. I got 48mpg! now that I think back when I get 45 or above mpg it is cooler. Strange
Have you ever noticed yours better in cooler weather or is it the mountain air
Old Aug 17, 2007 | 09:55 PM
oldfartjc's Avatar
oldfartjc
Default RE: I never noticed...
I've never gotten higher then 39 mpg ever no matter what the temp. is.
Old Aug 17, 2007 | 09:59 PM
dirtdobber's Avatar
dirtdobber
I was only getting 42-43 mpg at best before my stage 1. Went with all vance and hines and screaming eagle.
Old Aug 17, 2007 | 10:01 PM
DocHarley's Avatar
DocHarley
Coolerair increases its density which will create more power but it should not raise you MPG. Maybe you had the wind to your back today?
Old Aug 17, 2007 | 10:07 PM
dirtdobber's Avatar
dirtdobber
DocHarley
that is one sweet ride you have there
Didn't notice I was smilling too much
Old Aug 17, 2007 | 10:08 PM
FX4's Avatar
FX4
If you are making more power then you're a little lighter on the throttle for a given speed Yeah I noticed on a cooler day I do seem to pick up a mile or two to the gallon cruising.
Old Aug 17, 2007 | 10:10 PM
Strat's Avatar
Strat
The cooler the air the more dense it is. The more dense the air the more that will fit in eachrev of the cylinder. More air, more power, less throttle to get you where your going.
If that's not it, it's cause you ride alot faster when it's hot to cool down. So you burn more go juice.
I get better mpg as well when it's cooler
Old Aug 17, 2007 | 10:12 PM
notorious's Avatar
notorious
I'm getting 45 with half and half two up riding moderatly, however when I throw the coals to it, it drops to around 41 on the SG-T-Max withV&H's.
Old Aug 27, 2007 | 10:55 AM
dirtdobber's Avatar
dirtdobber
I did a test one might say last Sat... It was a cool 68 degrees and rode 130 miles; got 46.67 mpg. On the return home it was 95 degrees and the same milliage. 130 miles got 44.2 mpg. I used the cruise both ways with good traffic. Rode the same speeds also. Yes, I am sure during the 100+ weather I might ride faster but not by much. I am a older guy and like to cruise. I have another bike I ride when wanting to get somewhere fast or faster.
Old Aug 27, 2007 | 10:58 AM
Akitakoi's Avatar
Akitakoi
What is that monstrousity in front of your motorcycle?
dynarider1821
2014-2024 Touring Models
Oct 19, 2017 12:57 PM
James322
Aug 25, 2016 09:02 AM
HDmikie
Oct 18, 2013 02:36 PM
BaldHOG1222
Nov 18, 2012 01:00 AM
rdam
Mar 20, 2010 08:24 PM
