2019 Road King Special - Error Code
Mounted new handlebars (pre-wired with new controls, plug-n-play).to my 2019 Road King Special.
Removed the OEM handlebar-mounted turn signals for a set of flush mounts (similar to these https://www.revzilla.com/motorcycle/...yABEgLK4vD_BwE).
The pre-wired handlebars have the turn signal pigtail (white, red, black, blue) dropped out of the handlebar controls.
Leaving that pigtail disconnected is throwing a b2206 code. Cleared code, but it comes back every time I turn on the ignition.
Any thoughts of what I have to do with these open 4 wires (on each bar end) to stop this code?
The new, flush-mounted are working great. Just need to figure out what I should do with these open wires to stop the code from being thrown.
Huge t
hanks in advance.
B2206 Run/stop switch input open/shorted high
Are you sure the code is related to your "turn signal pigtail", and is your kill switch is operating correctly?
