Motor swap
Old Oct 21, 2022 | 09:22 AM
Max Headflow's Avatar
Max Headflow
Originally Posted by Keithhu
Missed that. Frame differences as well. Probably could be done with enough skilled surgery and money, but worth it?
The 07 bagger frames are pretty much the same as 06-earlier. It has the same motor as the 2012 except that the 2012 uses a motor mount off the front head. Have to use the old top motor mount bracket. Other than that it will bolt in.
Old Oct 21, 2022 | 09:58 AM
hattitude's Avatar
hattitude
Good info.....
I was unaware it would be a straight bolt-in fit....
Old Oct 21, 2022 | 10:33 AM
Max Headflow
Good info.....
There have been a couple guys here that have done the swap..
The only other issues will be that the 01 and earlier used a 5/8 swingarm pivot shaft and the later is 3/4. At that point it'd be better to go to the later swingarm and a 1in rear wheel / axle.. It's not too hard to bush the hole it wanting to stay the with original swingarm but they are known to crack at the rear axle. The center of the wheel can be bored out for the center spacer. Bearing ODs are the same. Wheel spacers need change and the caliper mount need boring where the axle slides through.
I've seen a minor clearance problem with the early left swingarm bracket and primary case but others say it's not an issue.
Old Oct 21, 2022 | 02:41 PM
Rounders's Avatar
Rounders
Will he have a second post? Bore to 95" cam and port, non epa will produce maybe better numbers than factory 103. But still have to live to tune MM.
Old Oct 21, 2022 | 03:40 PM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
Short answer is YES. But a lot of work.
My buddy has a 1994 (or 1996) FXR with a 2016 twin cam 103 out of a Road King. It's gets a bunch of double looks, somewhat of a bastard case, but it rips!!!
It isn't pretty but he does wheelies, smokes the tire every time he can!
YB
Old Oct 21, 2022 | 03:45 PM
09 YELLOWBIRD
And it's now has a Carburetor on it too.
YB
Old Oct 21, 2022 | 03:55 PM
Max Headflow
YB
I put a early TC bagger drivetrain into a aftermarket FXR and all I had to do was lower the crossover brace under the tranny.. I'd expect that with a stock FXR frame, the rear brake master might need to move but I know a guy that has fit TC motors in FXR frames without mods.. Need a special oil pan tho.
Old Oct 21, 2022 | 04:10 PM
09 YELLOWBIRD
Max,
You are correct. He also had to make a special tranny pan, added some sportier parts for the brake pedal, welded some other stuff, etc. etc. He also added the newer Brembo brakes F&R. I will have to snap some photos to share with you when I catch up with him.
My other bro has a 2019 CVO that's up near $80K including Bike and a ton of aftermarket parts that Brook at Brook's Cycle works in NC added to it. It's a beast of a Touring bike pushing 167 HP 163 TQ. His pipe is holding him back some. Anyway, my other bro with the Twin Cam FXR smoked him!
FXR Weight to Ratio is King!
YB
Jersey Drew
Jun 20, 2021 07:29 PM
whylee
Milwaukee Eight (M8)
18
Feb 19, 2021 12:54 PM
xbrashearsx
Nov 5, 2011 02:31 PM
El Chiguete
Exhaust System Topics
Mar 28, 2011 07:22 PM
El Chiguete
EVO
Mar 28, 2011 07:21 PM
