2010 Strret Glide
Old Oct 28, 2022 | 04:50 PM
Edrobo's Avatar
Edrobo
Stage II
Default 2010 Strret Glide
Bought my first Harley this past April and just recently having issue when starting what seems like slipping in the primary then eventually starts . Sometimes worse than others or not at all. Please let me know your thoughts
Old Oct 28, 2022 | 07:28 PM
Hawg Runner's Avatar
Hawg Runner
Bendix drive, comperstating sprocket, clutch slipping, bad teeth on clutch basket, or bad teeth on starter drive?
Old Oct 28, 2022 | 10:22 PM
Steelernation's Avatar
Steelernation
Compensator
Old Oct 28, 2022 | 11:40 PM
tully_mars's Avatar
tully_mars
Could be starter clutch. If when you press the start button and it starts to turn over but then spins out that would be the starter clutch slipping.
Old Oct 29, 2022 | 01:35 PM
Edrobo's Avatar
Edrobo
Stage II
Default Thank you
Thank you this is exactly what it's doing so wasn't sure if it was best to get starter out and take apart but will probaly go ahead and purchase starter what do you think? Just wanted to make sure something else wasn't going on in primary . Another question so you think i need to get into primary or this could be all dome from other side?
Old Oct 29, 2022 | 03:08 PM
Vec's Avatar
Vec
If it was mine, I would drain and remove the outer primary and figure out what's happening before buying anything. 🤔
Old Oct 29, 2022 | 03:13 PM
Fireball Jack's Avatar
Fireball Jack
Dont just throw parts at it. Take the primary cover off and examine it.
Old Oct 29, 2022 | 03:17 PM
pgreer's Avatar
pgreer
Agree with Vec, remove the outer primary to see what is going on. It would be a good time to have a look inside and check for problems.
I didn't see the mileage listed, but there were some compensator failures that typically started with clunk noise on start up and shut down.In more severe cases, the compensator ramps can slip and not crank the engine over.
If the starter clutch is bad, I'd replace that rather than a complete new / rebuilt starter. It's not difficult and much less expensive.
Paul
TBL2021
Jul 7, 2022 10:04 AM
TBL2021
Aug 19, 2021 07:56 PM
Brooklyn Devil Dog
May 8, 2010 10:57 AM
reded
Dec 27, 2009 11:58 AM
zeppelin316
Sep 4, 2009 01:40 AM
