2015+ Road Glide Owners: Are your T-bars/MX bars and riser blocking your radio
Old Nov 1, 2022 | 11:49 AM
jac737's Avatar
jac737
Default 2015+ Road Glide Owners: Are your T-bars/MX bars and riser blocking your radio
Hello all,
I am debating switching out my 12" KST Spearheads for some T-Bar / MX Bar style handlebars. However, I just went through a very tedious process to convert my 2015 RK into a RG, and I have a gorgeous HDHU14+ head unit that has been amazing. I love having the carplay stereo available to me on longer trips, and I am not willing to give up the use of the screen.
However, having run T-Bars on my Dynas in the past, I am thinking about making the jump. So my question:
For those of you running T-Bars or MX Bars+risers, is your screen blocked from your view? Also, which bars and/or riser setup are you running?
Thanks in advance!!!
Old Nov 1, 2022 | 07:44 PM
Slingshot383's Avatar
Slingshot383
YES, LA Choppers have a bar that doesn't cover up the infotainment center but is still narrow at the top and only 31" wide.
Old Nov 2, 2022 | 06:23 AM
slodsm's Avatar
slodsm
Depending on what is a comfy pullback for you , the la choppers Kage fighters are either gonna cover part of the gauges anyway, or cover the screen.
I went this way on my 17 in an effort to avoid buying a gauge relocation and spending the money, now I’m spending the money twice because I can only see 1/2 my gauges.
Thrashin 6.5” risers, pullback plate, mid bend bars, and gauge relocation bracket will get you a clear view of both gauges and head unit, it’s about 1500 bucks vs the 450 or so from Kage Fighters. But now I’ll be out 1950 instead of 1500 because I tried to save a few bucks.
After 28 years of hot rods and bikes, I should understand “buy once cry once”, but sometimes I still make mistakes 😂😂
Old Nov 2, 2022 | 10:35 AM
NoRegerts's Avatar
NoRegerts
All the T bars I have seen block at least some of the infotainment. With the Wolf One from Kraus you loose the bottom inch or so. With the Moonshine Kraus kit you don't loose any view, but it's expensive.
https://shop.moonshineharley.com/pro...id-gauge-mount
Old Nov 2, 2022 | 12:29 PM
jac737's Avatar
jac737
Thanks all. I have decided to do a few things that should get me where I want to be:
1) Thrashin Supply 6.5 pullback risers
2) Thrashin Supply RG adapter
3) Thrashin Supply High Bend Bars
After the feedback here AND some additional feedback on a few RG facebook groups, I decided this is the best way to retain the full use of my screen. I care less about the gauges, and I think I am going to just rock the stock nacelle with the cut-out. I may even keep using a road king special console with the gauge on tank and bypass the issue of the gauges behind the risers (i.e. run both sets of gauges because the speedo/tach from RG must be wired up in order to allow gauges in fairing to function properly). The beauty of my rig is that I have a ton of RK parts available from my conversion, so I can mess with a few different setups until I find the one that works best for me regarding the gauges.
Old Nov 2, 2022 | 01:03 PM
Puglia10's Avatar
Puglia10
I think a lot of guys here are confusing the screen with the gauges.
The screen is pretty hard to block unless you go really tall or move your gauges to the top clamp.
I have 14" Tbars and can see 100% of my screen.
The gauges are a different story, theyre totally blocked. With my old 6.5" risers I could see most of them, but not the odometer and the lower numbers.
Jersey Drew
2014-2024 Touring Models
Apr 15, 2017 09:12 AM
49mercuryman
Oct 16, 2016 05:46 PM
MegaFauna
Oct 5, 2014 10:04 PM
SweetGlide96
Aug 28, 2013 12:28 PM
sunnenman
Aug 12, 2013 01:21 AM
