You Ohlins guys were right!
Old Nov 6, 2022 | 09:51 AM
Old_Bikes's Avatar
Old_Bikes
Default You Ohlins guys were right!
My 2013 Rk started out with air shocks that I thought were not too bad, but definitely could use improvement. I got some of the dial adjustable take offs from a buddy with a 2017 RK, and while they were ok, I did not really like them. Then looking at how they load the two sides of the swingarm differently, I decided to dump them. Same buddy had installed Progressive 490S which I picked up from him. The bike handled great and they were decent except for the compression damping, which made some of the bridge joints on 280 feel like I was going to be shorter from spine compression by the time I got to work. I replaced springs, messed with compression and rebound, but never got it smooth.
I started looking at replacements and narrowed it down to Ohlins and Fox, and one Saturday a few weeks ago I got a text from the local dealers that they were offering $200 off suspension components. I went down and got a set of 159s, and boy did they change the ride. The Road King now rides smooth as butter and still handles great. I may still have some tweaking to do, but with the setting as recommended in the docs, the ride is near perfect. Should have done this a long time ago. The CVO is next.
Old Nov 6, 2022 | 10:06 AM
RKZen's Avatar
RKZen
Glad you like them. I have the 12" version (sans the rebound adjustment) for my King. Same stroke, but I need to get closer to the ground.
Old Nov 6, 2022 | 05:27 PM
Redrodyankneck's Avatar
Redrodyankneck
I brought the ground up tp me with a shaved seat mod and custom soles on my riding boots.
When I bought my 1st SGS in 2017 I ended up getting Ohlins. I ended up buying Ohlins from Howard @motorcycle metal because that was the only place where you could get a12" shock with 3" stroke. Howard, rest his soul, used new Olin parts to make that happen and at the time Ohlin, the mothership only offered a 2" stroke. I bought the entry level emulsion shocks and the were far superior to the HD stock shocks.
I put 13" Blackline 772's on my current ST and transformed the ride, far better than the emulsion shocks and now I have adjustable rebound. The bike is only 1/2" higher than my previous specials due to the 1" presag with the 13" shocks. I wish the bike was a bit lower because of my 27" inseam but I love the taller stance of the bike and I am no longer dragging floorboards where my special would.
Bottom line is I love my Ohlins!
Old Nov 6, 2022 | 06:57 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Save money for the front suspension. You quickly notice how inferior it is now with the better rear suspension.
Old Nov 6, 2022 | 10:49 PM
Old_Bikes's Avatar
Old_Bikes
No kidding. I was out for a short ride today and it really became apparent that the Road King front may be ahead of the CVO. I have the Progressive Monotubes in there, and they are better than stock, but still kind of harsh.
Old Nov 7, 2022 | 12:10 AM
RKZen's Avatar
RKZen
I have those monotubes as well. Am looking into the Ohlins or JRI, possibly a winter project but haven't decided. I've visited Ohlins and they gave me a factory tour. JRI is a few miles from me, so I'll have to give them a peek.
Old Nov 7, 2022 | 07:34 AM
NoRegerts's Avatar
NoRegerts
I have Ohlins in the rear. Waiting on the GP cartridges for the front to come in so I can install them. They were pricey, but I doubt I'll be able to outride them.
Old Nov 7, 2022 | 09:24 AM
eaglefan1's Avatar
eaglefan1
First thing I changed out on my bike when I got it was to the Blackline shocks. No more vertebrae jarring hits. Took a little while to get them adjusted where I want them, but well worth it. You get used to the ride and forget how bad the OEM shocks are until you take a different bike out for a run. Well worth the money.
Like everyone else, fronts are next after audio upgrade
Old Nov 7, 2022 | 07:58 PM
Bafflingbs's Avatar
Bafflingbs
I’ve had the 159’s on, for about 6 years now. They’ve never been serviced, and are still awesome!
Old Nov 7, 2022 | 08:43 PM
scott7d's Avatar
scott7d
I'm glad you like them. A good rear suspension set up correctly is a great upgrade from stock. I have Ohlins 772's and don't care for them compared the ProAction set I had. But still a major improvement from stock. I've tried to dial them in more with help from the seller (Carol "Smarty" Burks) but will eventually go back to ProAction.
