Tool Geeks
Old Nov 17, 2022 | 07:30 AM
702's Avatar
702
Default Tool Geeks
Have any of you used this filter wrench on a touring bike?
Popular Reply
Nov 17, 2022, 09:03 AM
malfvnction's Avatar
malfvnction
Oil Filter Relocation. Easy off and on. Clean up is a breeze.
Old Nov 17, 2022 | 07:37 AM
YZR's Avatar
YZR
Looks like a complicated tool to do a simple job (Rube Goldberg?)
Old Nov 17, 2022 | 07:45 AM
Goose_NC's Avatar
Goose_NC
Not enough room on my 2019 FLHTP. I use a oil wrench, extension and ratchet and my filters release with a pop.
Do not see a two finger tool doing it.
Old Nov 17, 2022 | 07:55 AM
NoRegerts's Avatar
NoRegerts
I use the oil filter wrench with an extension. Fits into the tight spot and easy to use. I do not see that device fitting into the tight spot it needs to fit into. I imagine hand hand and the frame rail will fight for space and the frame will win.
Old Nov 17, 2022 | 08:04 AM
Spartanden's Avatar
Spartanden
Interesting concept. I see how it works, but I don't think there's enough room on the touring to get in there and have room to squeeze. Maybe other applications, but not my Street Glide!!
Old Nov 17, 2022 | 08:09 AM
BuzzCap7's Avatar
BuzzCap7
When I wrenched (past tense), bike or cage, I found the one with the RED arrow worked best for me. Thinner width for the rubber band that goes around the oil filter.
I had a metal one that worked a little diff but there wasn't enough maneuvering room.
Old Nov 17, 2022 | 08:29 AM
MyFavRk's Avatar
MyFavRk
Just can't see getting enough leverage where the filter is located , especially if the filter is on too tight , which most are .
If your looking , the standard HD cap wrench is your best bet , add a 6" ratchet extension and it'll make the job effortless .
Old Nov 17, 2022 | 08:34 AM
touchdown's Avatar
touchdown
I like to use K&N filters because they have a nut on the end that you can use a socket on.
Old Nov 17, 2022 | 09:03 AM
malfvnction
Old Nov 17, 2022 | 09:52 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
With so little leverage I wouldn’t think it could release a snug, let alone a tight, filter.
