Headset Mic Problem
Old Aug 20, 2007 | 12:45 AM
Warden's Avatar
Warden
Default Headset Mic Problem
Hello all, I borrowed a headset that looks like it is a J&M behing the head headset. I hooked it up and for some reason it is not broadcasting loud enough to be heard. This condition is while sitting still in the drive way. The only change I did regarding my comm is I shortened my antennas by about 6". I only shortened it by snapping off the longest part. It transmitts but not very loud.
Any ideas would be appreciated. I am heading out of town in the AM.
Old Aug 20, 2007 | 05:22 AM
TexasRedneck's Avatar
TexasRedneck
Default RE: Headset Mic Problem
#1 - make sure the mic is almost touchin' yer lips.
#2 - for some reason, folks tend to talk softer when they've got a headset on - make sure yer speakin' in a clear, firm voice.
#3 - Git someplace (like a Truck Stop CB repair shop) that KNOWS CB radio, an' have 'em fix what ya screwed up. Antennaes are TUNED to a radio - one does NOT jest "snap off" a random length!!!!!!
Old Aug 22, 2007 | 07:08 PM
rinja64's Avatar
rinja64
I am having some of the same issues but it is with the passenger incom. Picked up a couple helmet speaker with mic sets from Whitehorse for $65.00 ea. Could not see paying $178.00 from Harley. Anyway, sound works from the radio in both sets. Rear volume control works. When I talk, radio mutes, passenger receives, radio goes back to normal. When my passenger speaks, and I told her to talk firm and with the mic up close, nothing. When I switched positions with hook ups, same situation, so both mics work. I read the manual - adjusted VOX and the AVC levels in every combination.
I did notice in the manual, it states only the Harley set up will work. Whitehorse shows as OEM, plug and play.
Thank you,
Old Aug 22, 2007 | 07:17 PM
Retired_Ted's Avatar
Retired_Ted
Why in the world would you "snap-off" 6" from a CB antenna - better order another, have it tuned, and DO NOT transmit on the one you have "pruned" or you may need a new radio too. Your SWR is probably sky high which can cause many problems including affecting transmit audio (like the problem you are now having).
dapster
Audio Systems
Jun 25, 2013 01:16 PM
Bosko
Aug 27, 2012 06:23 PM
hitchhiker2706
Apr 28, 2008 08:44 PM
jackja25
Mar 10, 2008 02:50 PM
swomack
Jan 25, 2007 07:51 PM
