Fuel Filter
Old Aug 20, 2007 | 08:49 AM
mwriggs's Avatar
mwriggs
Default Fuel Filter
On a '06 EGC, where is the fuel filter located? Can I cross reference on at a Auto Parts Store?
Old Aug 20, 2007 | 08:56 AM
xxxflhrci's Avatar
xxxflhrci
Default RE: Fuel Filter
It is in the fuel tank. It is a HD part.
Old Aug 20, 2007 | 09:46 AM
mwriggs's Avatar
mwriggs
I know you must be kidding.....never heard of a fuel filter being in the tank. How would you change it?
Old Aug 20, 2007 | 09:59 AM
sleepyjim's Avatar
sleepyjim
EFI it will be in tank I bet...........
Old Aug 20, 2007 | 10:38 AM
mrsr71's Avatar
mrsr71
Old Aug 20, 2007 | 10:43 AM
Peppa1's Avatar
Peppa1
If you have an EFI bike it is in the tank !!!
Old Aug 20, 2007 | 10:53 AM
Ultra_Bob's Avatar
Ultra_Bob
Copied from another site ..... Most OEM-style in-tank fuel pumps are equipped with a low-restriction inlet filter, often known as a strainer or “sock”. These filters often clip or screw onto the inlet side of the fuel pump.This is considered a coarse-element filter, and if you use an in-tank pump, this is a good low-cost alternative to an external coarse-element filter.However, we recommend that you still use a fine-element filter after the fuel pump to protect the fuel injectors.
Old Aug 20, 2007 | 11:07 AM
SoCal_Pappy's Avatar
SoCal_Pappy
Yep... In the tank.... and a HD Item only I been told...
Old Aug 20, 2007 | 11:42 AM
Retired_Ted's Avatar
Retired_Ted
It's in the tank in case of a rupture or leak - some guys have modified the location and have had problems with leaks (high pressure fuel near a heat source - yuk).
Old Aug 20, 2007 | 11:58 AM
kdietz's Avatar
kdietz
It's a total pain to change....while you're in there, be sure to change the fuel line also.....
