PINGING
Old Aug 20, 2007 | 08:22 PM
BEELINE's Avatar
BEELINE
6th Gear
Default PINGING
new 07 ultra ping bad in 5th & 6 gear at 2800 to3100 rpm all stock 3500 miles dealer states ok
Old Aug 20, 2007 | 08:31 PM
PhilM's Avatar
PhilM
Default RE: PINGING
The 07's were known to run lean from the factory. Pinging is NEVER "ok".
I'm sure some of the 07 owners will pipe in, but there are plenty of options to get a little more fuel in there to resolve the issue. You will find that it's worse now that's it's good & hot out.
There are plenty of tuning devices that will help.... PCIII, SERT, TMax, DTT, Cobra, FuelPak, etc.....
Old Aug 20, 2007 | 08:43 PM
shooter64's Avatar
shooter64
Former Sponsor
Default RE: PINGING
Phil is right, you are going to have to buy some type of fuel management....DTT or TMAX, anything else is a step backwards in my humble and unbiased opinion......lol
Old Aug 20, 2007 | 08:48 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Default RE: PINGING
If you're using the right grade fuel and it's pinging - Try changing Service Stations... If it's still pinging.... Ya better do the Stage 1 and richen up the fuel mixture.... Ping = Lean and pinging can pit your pistons....
Old Aug 23, 2007 | 05:12 AM
stu07hd's Avatar
stu07hd
Default RE: PINGING
I have no more pinging after the HD stage 1 download. Before the download I did have some pinging depending on what type of gas i pumped. I always used the highest octane available, but noticed on discount brands 92 octane the pinging was worse. Since the download I have had no pinging even when using discount brand 91 octane.
Old Aug 23, 2007 | 07:19 AM
coldmcrider's Avatar
coldmcrider
Default RE: PINGING
Stage 1 should fix it for you. I had the same issue till I put on a PC III, SEAC and SE II Mufflers.
Old Aug 23, 2007 | 12:06 PM
serverpimp's Avatar
serverpimp
Default RE: PINGING
Just exactly is pinging? Is it a predetonation in the cylinder before the piston hit top dead center? What is causing it? Too much gas or or air? Or is it a timing issue also.
Old Aug 23, 2007 | 12:09 PM
NCCopBikeRider's Avatar
NCCopBikeRider
Default RE: PINGING
Too Much air too little fuel, too much timing too much heat
All contribute to pinging
Ride Em cary Em
Old Aug 23, 2007 | 12:13 PM
StreetGlider56's Avatar
StreetGlider56
Default RE: PINGING
Too much bureaucratically BS...!
NCCopBikeRider
Default RE: PINGING
Ditto What he said
