CB Antenna Question
Old Mar 1, 2023 | 12:20 PM
Cbvanb's Avatar
Cbvanb
3rd Gear
Default CB Antenna Question
I have scoured the forum and can't find an answer to this particular question. I have a 2021 Ultra Limited and I have installed a cb module. there was antenna coax under the fairing to connect to the CB module, but I can't tell if the antenna mount is already connected. There is a ground wire attached but there doesnt seem to be a coax connection similar to the FM/WB antenna on the other side. Am I missing something?
Old Mar 1, 2023 | 01:33 PM
Ssitruc's Avatar
Ssitruc
The connector at the tour pack end of the coax is not the same style connector that is on the end of the coax in the fairing, that connects to the CB module.
#34 on the pic below should be there in the tour pack. One end should already be connected to the antenna mount already. You'll pop the plug (27) out, and there is a HD #76000166 $2 antenna stud that slides down into where the plug came out of and screws in to #46 (already there too)... that gives you the stud to screw your antenna on to.
The other end of #34 should be near or hanging out the front of the tour pack where the other wires come out... from the factory on mine that end was not hooked up. But the coax coming from the fairing was there, just coiled up and tucked down behind the battery... its there somewhere coiled up and hidden probably. Find it, uncoil it and connect it to #34 coming out of the fairing (the ends will have matching connectors on them). At the tour pack end the connectors are the kind that "slide together", not a threaded collar like at the CB module end. Then you should be go to go. All 4 harness/wires coming out of the tour pack has connectors close to the tour pack (AM/FM antenna, CB antenna, Lighting harness, & Audio harness), makes it easy to disconnect everything if you want to take the tour pack off).
Old Mar 1, 2023 | 03:52 PM
Cbvanb's Avatar
Cbvanb
3rd Gear
I appreciate the information. I found the coax under the seat and it was already connected. The single wire in the photo is what connects to the antenna. Is this all I need then?
Old Mar 1, 2023 | 04:04 PM
TriGeezer's Avatar
TriGeezer
I think there should be a ground connection to that big steel plate too. I’d look…but I’m without bike right now.
Old Mar 1, 2023 | 04:16 PM
Ssitruc's Avatar
Ssitruc
There is, its actually shown in that picture in post #3, that "tab" on the back of the metal pan is where one part clips to metal pan, and then the single wire in the pic going to the antenna mast. Thats all there is to it.
Old Mar 1, 2023 | 04:19 PM
Cbvanb's Avatar
Cbvanb
3rd Gear
Originally Posted by Ssitruc
There is, its actually shown in that picture in post #3, that "tab" on the back of the metal pan is where one part clips to metal pan, and then the wire in the pic going to the antenna mast. Thats all there is to it.
Thanks! I wasn’t sure that wire was all I needed.
Old Mar 1, 2023 | 04:21 PM
Ssitruc's Avatar
Ssitruc
Yeah, first time I messed with it, I questioned it too
Coyotejunki
Audio Systems
Oct 6, 2022 11:56 AM
Kozmo
Dec 8, 2021 09:23 AM
rock2r
Jan 2, 2018 05:04 PM
btsom
Mar 19, 2017 08:44 PM
Jukebox
Feb 10, 2009 04:22 PM
