04 road king classic / custom wheel interchangeable
Old Mar 15, 2023 | 04:40 PM
Billie696's Avatar
Billie696
6th Gear
Default 04 road king classic / custom wheel interchangeable
I’m fairly new to Harley’s so bare with me lol
I have a 04 road king classic and stumbled across some 04 road king custom wheels. It says in the description that the bearings are 25mm and 16x3. I was wondering if the wheels were interchangeable between the 2?
Old Mar 15, 2023 | 05:03 PM
GOGOBECK's Avatar
GOGOBECK
Rusted spokes& nipples…Your wheels look better!!!
Old Mar 15, 2023 | 05:17 PM
jimglassford's Avatar
jimglassford
$250 for a pair of rusted rims? It is amazing what some E-Bay sellers pull out of the garbage.
Old Mar 15, 2023 | 05:25 PM
Stiggy's Avatar
Stiggy
To answer OP's question, yes the are interchangeable.
Old Mar 15, 2023 | 05:29 PM
Billie696's Avatar
Billie696
6th Gear
I also thought the price was to high
someone also told me that since the wheel bearing is 25mm it will not be a direct fit on the road king 1 inch axle
Old Mar 15, 2023 | 05:36 PM
roussfam's Avatar
roussfam
That is my understanding as well from a previous thread.
Something about 25mm is not 1", It's .98" so you can't slide a 1.00" axle through a .98" hole. Also something about the 25mm bearings are thinner, so the recess is not as deep as a hub that uses 1" bearings, so if you tried to install 1" bearings in a 25mm hub they would be sticking out the sides. I'm sure someone with first hand experience will be along shortly to answer your question
Jim
Old Mar 15, 2023 | 05:38 PM
GOGOBECK's Avatar
GOGOBECK
The RK Classic came with laced wheels, someone swapped ‘em out for the mags. Looks like they painted them too!
Old Mar 15, 2023 | 05:46 PM
Billie696's Avatar
Billie696
6th Gear
Thank you guys for the info and help! I’m more of a laced wheel kind of person but I do like the mags so I’m going to keep them for awhile .
Old Mar 16, 2023 | 12:03 AM
TylerScott85's Avatar
TylerScott85
Default Nice bike
I’ve never seen those wheels before and I like them! Especially color matched. But I guess it depends on what look you’re going for. Any idea what size bars those are? Sorry I don’t have any useful info on wheel swap.
Old Mar 16, 2023 | 12:32 AM
cpmedina's Avatar
cpmedina
Stage II
Those are the road king standard rims. Classic did come with laced wheels. Drag specialties has laced wheels oem for the king. They take stock bearings, but you have to reuse your spacers. Make sure you install the primary brake bearing first to get proper offset. Primary brake side has a line under the brake rotor. Get the service manual. It helps. Good hunting.
