Triglide Wind issues
Old Mar 27, 2023 | 10:00 AM
samk9lover's Avatar
samk9lover
Default Triglide Wind issues
The wind coming over my tank on my 2022 Triglide is a PITA. . I've looked into tank lifts and wind deflectors. What are others doing to help with this problem? Thanks for any help!
Old Mar 27, 2023 | 10:04 AM
Goose_NC's Avatar
Goose_NC
Madstad windshield system...
Old Mar 27, 2023 | 10:52 AM
Spartanden's Avatar
Spartanden
I have buffeting issues with my Street Glide. Place your arm horizontal across your chest and see if this reduces the wind. If so, it is coming from below the fairing. I had fork fangs on my Glide, which eliminated the buffeting. Then I started to notice a lot of heat from the right side. I removed the cat, which helped just a slight bit. Then got to reading DK Custom you tubes and ended up doing the following: remove fork fangs, installed front frame deflectors (they mount on the lower tank mtg bolts) installed tank lift, and added a mid frame deflector on the right side. This seems to help move air over the engine, reduce heat, and eliminated buffeting. Maybe if you contact DK they may have some suggestions. Or check out their you tube videos.
Old Mar 27, 2023 | 11:46 AM
CoolBreeze3646's Avatar
CoolBreeze3646
I put these on my Tri, seems to help with the wind coming up under the fairing and over the tank.
Cooling Deflector Wings for Touring / Trike Models
https://www.dkcustomproducts.com/coo...dk-cdw-trg.htm
Old Mar 27, 2023 | 11:54 AM
BigD48's Avatar
BigD48
I installed a set of these. They work well.
https://www.glideairdeflectorsystem....ra-glide-2014/
Old Mar 27, 2023 | 12:16 PM
TriGeezer's Avatar
TriGeezer
Open the fairing vent, and close the little side wind deflectors, I didn’t have any issues then…
oh yeah, it’s a motorcycle…you might get some wind in your face,
Old Mar 27, 2023 | 02:19 PM
itsmf's Avatar
itsmf
Try the genius/politicians on the trike talk forum!
try the genius/politicians on the trike talk forum
Old Mar 27, 2023 | 03:52 PM
Red's Avatar
Red
I bought the Baker Wind Blockers a few years ago for my Limited. Almost 150,000 miles later I'd buy them again. They aren't pretty but I won't win any beauty contest either. At 71 it's all about comfort for me.
I only have one eye so if my head bounces I can't focus. With the Bakers you can easily reach down and open or close them. They are fully adjustable while riding. Great in cold weather and in the rain.
Your problem is the air coming from under the fairing then coming upward. You can replace your shield with anything you want. It won't help!
Good luck....
Leverlution
May 25, 2018 03:45 PM
desertclassic
Jul 22, 2015 01:29 PM
HDBri
Aug 12, 2014 04:23 AM
ejvette
Nov 5, 2013 09:18 PM
mirage2521
Sep 17, 2006 12:53 AM
