Brake pedal adjustment???
Old May 6, 2023 | 07:36 PM
Scheers44's Avatar
Scheers44
Default Brake pedal adjustment???
Hopefully someone’s got some help here.
I’m running a Pm contour brake pedal assembly and it was touching heat shield on OEM exhaust, figured no biggie new pipes probably solve that issue. So just got done fitting new 2-1 Khrome Werks and no dice.
So my question is this, does anyone know if/how the pedal angle can be adjusted?
Old May 6, 2023 | 07:46 PM
gonemad's Avatar
gonemad
Seeing that it is just a replacement brake pedal I don’t see where this one would have any adjustment, just like the OE pedal doesn’t either.
If it makes you feel any better I had to change brake pedals to fit some added parts on mine. I usually end up buying at least two of everything by the time I get the bike like I want.
Old May 7, 2023 | 08:41 AM
Ultra103's Avatar
Ultra103
Might be easier to tweak the shield a bit than adjust the pedal.
Old May 7, 2023 | 10:08 AM
Tired's Avatar
Tired
The pedal angle can be adjusted by applying force until the pedal ends up where you want it.
Carefully bend it.
Dan89FLSTC
EVO
Jul 25, 2020 09:13 PM
Vastinej
Aug 20, 2018 03:57 PM
oldgeezermike
Oct 20, 2013 05:02 PM
hazinthehides
Mar 11, 2011 09:26 AM
bruce sg08
Jul 20, 2008 05:18 AM
