2021 RGL not tracking straight
Old May 24, 2023 | 09:45 AM
Zonktified's Avatar
Zonktified
Originally Posted by NorthWestern
Mine does. I know it may be an anomaly but I can ghost ride thing for miles, If I wanted.
Same here...I don't think it is "completely normal" for a bike to track off to one side or the other, that is a balance issue. Aside from the normal crown of the road surface, you will get some tracking but, if your bags are loaded evenly the bike should track straight.
Old May 24, 2023 | 12:49 PM
V-Twins & Bowties's Avatar
V-Twins & Bowties
New frames are four point mount. This did away with the older adjustable three point mounting with adjustable arms.
Hence the non adjustable arm at top of drive train on newer frames.
Old May 24, 2023 | 01:38 PM
Zonktified's Avatar
Zonktified
That's interesting to know. So is there a "fix" for those whose bike is not tracking right? My old Honda Shadow 1100 did that and it drove me absolutely nuts.
Old May 25, 2023 | 05:37 AM
V-Twins & Bowties
There is no adjustment of the four point mounting per say. How ever there are things that can effect the tracking as has been discussed.
One thing that has not been mentioned is the front drive train mount that bolts to the engine cases. Two bolts secure this piece to cases and I believe it's not a pinned part. In other words it could cause a misalignment of the power train.
Can it be enough to effect the alignment.................I don't know as I've not messed with one.
Old May 25, 2023 | 05:45 AM
cannot's Avatar
cannot
My previous 2018 FXBB and current 2021 FLHR do the same, always lean left.
Old May 25, 2023 | 06:03 AM
jimglassford's Avatar
jimglassford
This same topic has been discussed multiple times in the past and the general consensus is the Harleys do not track straight. Although it would be nice to release the handle bars and the bike stay straight, they don't. I can tell my Road King takes a little uneven twist in the handle bars while riding.
Candubrain
Aug 4, 2014 08:34 PM
Ken Baer
Mar 19, 2012 07:20 AM
MX Mark
Dec 3, 2010 08:51 AM
jrsmith_80
Aug 5, 2008 04:54 PM
Aaron01
Jul 31, 2008 01:20 AM
