HELP! EFI Throttle partially stuck open
Old May 31, 2023 | 08:05 AM
JoeTheAnvil's Avatar
JoeTheAnvil
Stage III
Default HELP! EFI Throttle partially stuck open
2011 Street Glide, I was in a parade Monday and the bike was pretty hot. I throttle up to rev (for the crowd) and it stayed at 3000RPMs. The engine light came on and I had the P1511 code. The throttle itself feels fine, snaps back, etc., but even after letting it cool down and inspecting what I could see of the throttle body and connections, it's still going to 3k on start-up and staying there unless it's under load. It is beyond my limited knowledge, I'm tempted to buy a new TPS but I don't want to just throw parts at it... any other ideas for what I should look at?
Old May 31, 2023 | 08:27 AM
Keithhu's Avatar
Keithhu
If I'm not mistaken, that code is generally associated with fretting where the sensor connects to the ECM, solution is generally to pull it apart, clean the prongs, apply a small amount of dielectric grease, reconnect, clear codes.
Edit - I dont see that code in the TSB I was thinking of, so probably not the issue.
Old May 31, 2023 | 08:48 AM
JoeTheAnvil
Stage III
I didn't have the dielectric grease on the side of the road but I did pull it apart, try to clean, and re-seat it. No change at that time.
Old May 31, 2023 | 08:50 AM
Keithhu's Avatar
Keithhu
Have you tried something like this>? https://ridermagazine.com/2009/02/12...01%2C000%20rpm.
This is essentially what's buried in that article:
Built into the system is a reset function. If the ignition is turned off with the throttle in a position other than 0 percent throttle, the system wants to use a higher rpm as the new idle speed the next time the engine is started. If you shut the bike off at 1,800 rpm, the next time you start the engine it will use approximately 1,400 as the new idle speed. To keep this from occurring you can reset the idle by turning on the ignition switch until the fuel pump cycles on and off, then turning off the ignition. Repeat this three times and the idle speed will be reset to normal, 1,000 rpm.
Old Jun 29, 2023 | 09:51 AM
JoeTheAnvil
Stage III
just to follow up on this--I learned some lessons here. After a week or so of online research, and questioning friends that know stuff, my suspicions were correct, it was very likely the throttle position sensor. I had seen throttle bodies (where this thing lives) for $5-800 and was in a panic over it because I was in between jobs but also saw hundreds of TPS switches out there for $20-50 but I could not find the correct one or part number to find it anywhere. Out of total frustration, I went down to the only HD dealer open on a Sunday in the area and explained the situation as best as my non-mechanical brain could.
Parts Guy: you can't find it because Harley doesn't sell it...
Me: ummmmmm....
Parts Guy: you have to buy the whole throttle body...
Me: ....
Part Guy: it'll run you about...$230 but I think they're on backorder... supply chain....oh wait, we have one in stock.
Me: SOLD! How hard is the install?
a few hours and youtube videos later, I pulled the air filter, intake, seat, tank, etc., my friend helped me with the actual install, and reassembly and I was back on the road! The throttle response seems slightly better but that might be in my head.
so, probably a sensor worth $5, cost me $240ish (couple gaskets, etc.,) a 12 pack of Blue Moon for a friend, a few hours, and some laughs.
Old Jun 30, 2023 | 07:15 AM
b0fh's Avatar
b0fh
the joy of fixing it yourself is priceless.
Old Jun 30, 2023 | 10:21 AM
TriGeezer's Avatar
TriGeezer
But, make sure the throttle grip is fully closed when doing this.
freashman06
Jul 11, 2022 07:42 AM
softtail guy
May 2, 2022 05:57 PM
Caine01
Aug 23, 2015 02:23 PM
tcataldo
Feb 28, 2012 07:11 PM
Dynarider04
May 30, 2011 03:54 PM
