Compensator for an 09
Old Aug 30, 2023 | 01:59 PM
  #71
Max Headflow's Avatar
Max Headflow
Originally Posted by Rounders
The dynas got the new oil pump 2006?? Odd they rolled it out that way.
Either way the guy forgets about tc88 in video.
They got the new oil pump (not needed) and hydraulic tensioners. They also got the new starter, new comp, new clutch outer. new tensioner, etc.
Old Aug 30, 2023 | 07:24 PM
  #72
hattitude's Avatar
hattitude
Originally Posted by cosmo glider
I replaced the "A" version tensioner in my '09 stage 1 RG a couple of years ago with the "C". Comparing the two I didn't see anything different except for the things you noted and visible in the pic. I didn't see any additional plastic on the "C". The spacers used on the "A" are removed and not needed to install the "C" and (my speculation) might improve the strength and stability (less flex) of the tensioner because it has better contact with the inner primary, I've been keeping a check on the chain tension by removing the derby cover and using a long screw driver and a flashlight every 1000 miles or so and so far it has been ok. I would be interested to learn which parts are plastic on the "C" that you heard about.
Thanks.
While in a discussion on another forum, a trusted source mentioned the "C" version had plastic.
I have never actually held one, but found a pic of one. It looks like on the top portion of the mechanism attached to the shoe, the upper ramp with the teeth that rides on the bottom ramp, is made of plastic... On both the "A" and "B" versions, both ramps with teeth were metal...
Here's the pic I used that led to my comment... But like I said, I've never held one myself... If I am seeing this wrong, please set me straight...
Old Aug 31, 2023 | 03:34 AM
  #73
cosmo glider's Avatar
cosmo glider
Next time I remove the primary i will take a look at the part you pointed out but I don't remember it being plastic. Then again things sometimes don't register with a high mileage memory such as mine.
If you hear of any issues with the "C' let us know.
Old Aug 31, 2023 | 05:10 AM
  #74
Jehu's Avatar
Jehu
Originally Posted by Pantera99
Has anyone considered Baker? Just watched a good video on the install, spring pack on outside, looks kinda slick. BTW if I understand it correctly it looks like the '09-'10s have the worst stock compensator to begin with?!! WTF?!
My 2010 RK, purchased fall of '09, barely made it 17,000 miles before the compensator had to be replaced, I went with the later model/SE set up and so far it's OK.
Bike has stock (Stage 1) TC96, ridden solo, warmed up before getting revved (sometimes short-shifted the first few miles) or having load on the engine when really cold. It is serviced more regularly than recommended and ridden pretty conservatively. The kick-back on hot starts was just getting too annoying and I figured the starter wasn't liking it much either.
Not more than a few thousand miles after the compensator replacement the starter motor went - should've saw that coming.
Old Aug 31, 2023 | 07:17 AM
  #75
Rounders's Avatar
Rounders
Can you see any damage on compensator or going by kick back and loud noise? I've had my 07 off few times, but sure what to look for.
72k. I don't do fast starts. I like cruising fast, but not taking off. I used to do engine breaking,but don't much snymore
huffy
Aug 30, 2023 01:37 PM
stilup
Oct 20, 2013 12:58 PM
donutsrd
May 20, 2009 09:40 AM
honestbob
"The Florida Crew"
May 10, 2009 11:46 AM
