Slipon bolts
Old Nov 18, 2005 | 04:21 PM
Mikeeeeeeeeee's Avatar
Mikeeeeeeeeee
"Moderator & Connoisseur of Ice Cream"
Default Slipon bolts
Got to work today and looked down as I was disrobing from my cold weather gear and saw that my RH slipon was sticking out further than the left.
Sure nuff..............loose as a goose. Both the bolts for the rear bracket and the muffler clamp are loose.
I'm at work and dont have my manual with me. Anyone know the torgue settings for those bolts? I want to torgue before the ride home.
Mikeeeeeeeeeeeeeeeeeeeee
Old Nov 18, 2005 | 04:47 PM
myzen's Avatar
myzen
Default RE: Slipon bolts
45-60ft lbs
Old Nov 18, 2005 | 04:53 PM
Mikeeeeeeeeee
Thanks man!!!!
Old Nov 18, 2005 | 05:00 PM
luvmyflhtcui's Avatar
luvmyflhtcui
I know from experience that you should lean towards the 60 foot pounds as they will come loose quite easily. I went to Harley and the have a new clamp that will not loosen up once it is tightnened. It has a torque block in the center that won't budge. I feel your pain.
Good luck.
[IMG]local://upfiles/494/23086BECEFD44890B23E6253DF85D988.jpg[/IMG]
Old Nov 18, 2005 | 06:27 PM
Mikeeeeeeeeee
Might better check your occasionaly........Mine has th torque block!!!
I put some blue loctite on too. Got plenty of that at work.
Thanks guys!
Mikeeeeeeeeeeeeeeeeeeeeeeeeeee
Old Nov 18, 2005 | 09:22 PM
Neckball's Avatar
Neckball
My left side had slipped back last week. Strange thing was, the bolt was tight, had to grunt to get it loose. One more thing to add to the routine maintenence list.
Old Nov 19, 2005 | 06:25 PM
Danester's Avatar
Danester
45-60ft lbs
I did mine without a torque - -I put 6ft, 200pds of my fat AS$ into it and busted the darn clamp - - new clamp - - 10 bucks!
lucaso128
Apr 13, 2012 06:36 PM
forever young
Mar 22, 2009 10:03 PM
SilentWarrior
Jan 25, 2008 07:52 PM
beemer737
Jul 11, 2007 09:03 PM
anubisss
Oct 7, 2006 02:33 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
