Twin Cam to M8 Conversion
Old Aug 28, 2023 | 10:20 AM
bagman1's Avatar
bagman1
Default Twin Cam to M8 Conversion
Got a question. Is it possible to replace a TC engine in a non water cooled touring frame with a Milwaukee engine? Is it possible or just a pipe dream? TIA.
Old Aug 28, 2023 | 10:22 AM
eighteight's Avatar
eighteight
Engine mounting points are considerably different
Old Aug 28, 2023 | 10:40 AM
Fireball Jack's Avatar
Fireball Jack
Anything is possible with enough cash.
Old Aug 28, 2023 | 03:38 PM
bagman1's Avatar
bagman1
Wouldn’t be paying someone to do this for me. I would be doing it as long as theres some kind if conversion mount system.
Old Aug 28, 2023 | 04:03 PM
Fireball Jack
So you would be bringing to complete ECU, BCM and making the ABS work. and wiring with it?
Old Aug 28, 2023 | 05:17 PM
bagman1's Avatar
bagman1
Twin cam bikes have an ecm and abs. I would almost think that can be reprogrammed. Not sure what BCM is you’re referring to.
Old Aug 28, 2023 | 05:22 PM
M Oclaf's Avatar
M Oclaf
So you want to put a new motor/engine in an old frame?
Be a lot more than fabricating mounts.
Good luck
Old Aug 28, 2023 | 05:40 PM
bagman1's Avatar
bagman1
Thats why I was inquiring. Thanks for the info. Think I’ll stick to modifying old cars. Much easier.
Old Aug 28, 2023 | 05:44 PM
Keithhu's Avatar
Keithhu
https://www.roadglide.org/threads/bc...t-does.386067/
Twin Cams have BCMs as well, but there are different versions over the years and they are not 100% interchangeable across years. I don't have info on which BCMs are in which years/bikes.
Old Aug 29, 2023 | 07:23 AM
G E E's Avatar
G E E
Coming from guy that converted 07 RoadKing into 2012 RG with all OEM parts including 6gal tank . Why would you put M8 in 14 or under bike? Just cost alone ,I mean doing it yourself will be 3x what bike will every be worth.. I had plan to do full update on mine till I added up cost vs what bike might be worth and what it was worth as it sat… I sold bike $11k. Buy new to me 20RGS. Being building and riding it for last yer without 1 regret…. JMO.
now I love to see M8 in old rigid frame.
