Hi all, I’ve been chasing a noise on my 22 RG Limited for a while now with no luck. I have the following mods: Wood 22XE cam, Wood lifters, adjustable pushrods, Rinehart slipons, S&S teardrop breather.
The bike is quiet on startup and stays quiet all day, but when I hit approximately 3500 rpm I get a rapid ticking noise. It starts at the same rpm regardless of gear, speed, load. It does not go away or get worse as rpms increase, but the exhaust drowns it out by the time I hit 4000 rpm.
Any ideas?
You mentioned you have adjustable pushrods. Have you ever tried re-adjusting the pushrods. And are you using recommended oil viscosity. Singer sewing machine sounds are typical are some engines, usually the TC's. Not that familiar with the M8"s.
