engine running hot- need help
Old Aug 26, 2007 | 02:54 PM
NCCopBikeRider's Avatar
NCCopBikeRider
Default RE: engine running hot- need help
300 F is not on the danger side for an air cooled harley Motor. 300 F oil temperature is another sotry.
Is your head temperature being measured at the Spark Plug, with a thermocouple, or by IR (non contact) sensor?
Values will be different.
Good Luck
Ride Em carry em
Old Aug 26, 2007 | 03:05 PM
stro1965's Avatar
stro1965
[align=left]Sheldong, I checked my head temp logs after returning from Sturgis. My bike got really hot a couple times out there when I was silly enough to try to drive down the main drag and got stuck in the traffic jam from hell. I had hit head temps of 330, 340 and....370!! OUCH! No apparent ill effects, bike was still running great even when that hot. I did change the oil when I got home though![/align][align=left][/align]
Old Aug 26, 2007 | 03:51 PM
sheldong's Avatar
sheldong
i have retarded my timing 2' and backed AFR to 13.5.
i was wondering what options are available for oil tempo guages if you don't have a farring? anyone mount the wally version on a RK?
-sheldon
Old Aug 26, 2007 | 04:18 PM
sheldong's Avatar
sheldong
NCCOP,
i'm using a Tmax digital speedo that gives me access to the engine temp sensor. I figured it is a tc in front cycle, but havn't found it in service manual, except for schematics. is the same temp sensor that stock ecm controllor uses. I'm ready to try something different. BTW, bike runs strong, real strong it pulls. it is just the head temp got me scared.
- sheldon grooms
Old Aug 28, 2007 | 07:12 PM
sheldong's Avatar
sheldong
Default RE: engine running hot- need help- update
i just wanted to update those folks that read this tread.
i got one of those led temp readout dip sticks and have been watching my oil temp and engine temp since retarding my timing by 2'.
engine temp readout of 250-260, seems to go stable around 260 in traffic now as long as we are +20mph and when crusing i'm getting about 220-240'F +65mph. much improved.
oil temp readout to engine temp reading looks like a 30'F different when engine is running and about 10'F diff when engine is stopped
well oil temp has never gone over 230'F that i caught on readout , i've been driving in traffic on monday and tues and would have seen engine temp of 270-290'F. no prev oil temp data.
i also changed out my plugs after changing timing, so i'll probably stick those plugs back in.
anyway, thanks to everyone who helped.
-sheldon
firehawk6
Jun 18, 2018 03:21 PM
DavidStiebel
Sep 16, 2017 10:23 AM
PLHbrian
Exhaust System Topics
Apr 22, 2010 03:04 PM
truckerdave
Sep 6, 2009 10:19 PM
smadge
Mar 30, 2009 02:52 PM
