Faulty ABS Module-warning, rant in progress.
Old Oct 9, 2023 | 03:54 PM
uncle kebo's Avatar
uncle kebo
If you did not flush and cycle ABS the reason is you. Even BMW requires the 2 year flush. Bikes ABS is not like Cars.
Rant all you want you were lucky it lasted that long.
i agree w you smitty, i was gonna say the same. Bmw, hd, honda, triumph etc all require a 2 year flush. Lord knows a sitting bike is more suspect than one thats ridden too...
Old Oct 9, 2023 | 05:14 PM
strych9's Avatar
strych9
If you didn't test the moisture content with a tester, how do you know it wasn't full of moisture? Clean and clear doesn't mean anything. As a mechanic of 30 years (as am I), you ought to know that. Bike brake fluid has to be changed or at least tested every two years on an ABS bike, or you are gambling. Add to the fact that the ABS likely never cycled after the module replacement with the lack of use the bike had, you have a recipe for a failed ABS unit.
Old Oct 9, 2023 | 05:27 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Originally Posted by R1Geezrglide
Here we go-2013 FLHTK went 48k miles with no issues, owned by a close friend. Three years ago, his ABS module locked out the front brake. After flushing and bleeding, no change. He bought a new module from the local dealer, we installed it, flushed and bled and all was right with the world. He rode it maybe a dozen more times on short rides and parked it due to health issues. Last year, I bought the bike from him and found the front brake severely restricted but would work if pulled hard enough. It stops well with just the rear brake, but that is not how I ride. I recently went after the problem myself rebuilding the master cylinder-it was clean. No improvement. I found if I tapped on the module with a light hammer, it opened up, but would revert back even with the key off. I took to the local dealer to be told there was really no point in doing a power flush with Digitech as the module was faulty-likely due to moisture in the fluid. $1300 for a new module. I pointed out the system was thoroughly flushed when the module was replaced and the fluid was still clear and clean. He insisted on his lack of maintenance canned narrative, and I threw the BS card. For reference, I have 30years in automotive as tech, trainer and management. Also 8 years as a former HD service manager. The moisture narrative is just an excuse for a crap part. For context, I have a 1993 BMW R1100RS. This bike was the first major redesign for BMW in decades with first generation ABS and fuel injection. It still has all the original parts that still work perfectly. It is rarely ridden, but always works. I'm sorry for ranting a bit here, but there is no excuse for such a poorly designed part when really robust systems have been out there since the late 70s. As HD service manager, we replaced quite a few of these. Other forums have running threads on this issue. I don't know if anyone has a workaround other than bypassing the system altogether. It's amazing to me that the replacement part is still no better than the original, if not worse for such a critical system. At this point, I will be bypassing the system converting to non-ABS as I have no faith in the HD module.
Your absolute correct. There was one on YouTube someone cut apart. Sorry material and design.
In this case, it probably just set and corrosion stuck it.
I had thought the updated one was better since you don't see it on here much.
Someone ought to recall all of them simple how they fail. There supposed to fail safe. Maintaining normal braking with just a light.
Just like cars do. Cars also bleed just like non ABS systems did. They also fire the pump ever key on. Best I can tell, Harley's don't. So for some, the ABS may not get moved for year by some.
This system will kill you the way it fails.
Old Oct 9, 2023 | 05:47 PM
GalvTexGuy's Avatar
GalvTexGuy
I read somewhere that brake fluid has additives, among them are corrosion inhibitors, that break down over time. I would think when moisture is introduced, that speeds up corrosion. Also, I remember reading that the Dow brake fluid used in those bikes that were part of the 2018 recall was found to not meet Harley’s specifications. I’m only speculating, but I’ll bet the 2008-2011 bikes that were part of the recall were mainly affected by corrosion caused from the breakdown of the substandard additives and that’s what seized up one or both of the little plunger valves in the module.
Old Oct 10, 2023 | 02:08 AM
skratch's Avatar
skratch
moisture checks are one of the steps that are listed in your maintenance schedule every 5k. i bought a cheap tester off amazon, around $12 and test my fluid each service. hd says to change every 2 years or when moisture exceeds 3%. with the humidity here in la, that has been every year and a half.
point is, just don't think if you do it every 2 years you're good. you could need it more often than that.
Old Oct 10, 2023 | 06:58 AM
R1Geezrglide's Avatar
R1Geezrglide
Great idea. I was thinking about this as an option...Thanks
Old Oct 10, 2023 | 07:09 AM
R1Geezrglide
Understand, proper ABS systems have long tolerated moisture build-up in automotive systems and other motorcycle manufacturers. Only Harley is using the moisture excuse to provide cover for a defective part/design. Case in point-my 93 R1100RS. It's rarely ridden and hasn't been flushed in 10 years. Fluid is still clear and system is fully functional. Second issue is the fact the system randomly shuts off half the braking system leaving the rider at extreme risk. Were this a car, there would have been a huge recall. I talked to my friend, the previous owner, and he stated the bike probably wasn't ridden more than 100 miles after the module was replaced. I has been in closed storage until I bought it last year only being started every so often and the battery maintained.
Old Oct 10, 2023 | 07:24 AM
BRKLYN1955's Avatar
BRKLYN1955
Bypass >
Old Oct 11, 2023 | 07:41 AM
R1Geezrglide
Perfect!
Old Oct 11, 2023 | 06:17 PM
wide glider's Avatar
wide glider
Here's a question for an actual Harley tech working at a dealership in regards to the video above...
If someone was to bypass the ABS hydraulic valve unit like shown in the video or even gone a step further and replaced all the brake lines with standard lines direct from master cylinders to calipers is there a way using the HD digital tech software to reprogram the bike's ECM to now see a non-ABS bike and eliminate the ABS warning light? Or would this be viewed as tampering with the brake system with potential legal ramifications for the dealership? I'm talking about reprogramming the bike only with the owner swapping out brake lines for the non-ABS versions and bleeding the system accordingly.
