No Speedo
Old Oct 29, 2023 | 06:44 PM
vickers1's Avatar
vickers1
Default No Speedo
Went on a ride today and my speedometer went to zero. When that happened, cruise control went out along with the odometer and compensated speed volume. Stayed out most of the trip and would come and go.
A little research leans me toward the speed sensor unless someone leads me in another direction.
Old Oct 29, 2023 | 06:50 PM
kevin_n's Avatar
kevin_n
Same thing just happened to my wife’s bike, but hers turned out to be the gauge. There are was to test the speed sensor but I would guess that the sensor is bad or going bad. Did your turn signals self cancel like normal?
Old Oct 29, 2023 | 06:55 PM
vickers1's Avatar
vickers1
I never noticed if they did or not. What will that tell me? Did your wife’s bike do all the other things mine did?
Old Oct 29, 2023 | 07:25 PM
RoadieWingZ's Avatar
RoadieWingZ
Default What code(s) did it throw???
Start with the codes. Always.
Old Oct 29, 2023 | 09:07 PM
zibby72's Avatar
zibby72
4th Gear
Same thing happened to my 23 SG ST. It was ABS sensor that died with only 240 miles on it. Warranty repair and back on the road.
Old Oct 30, 2023 | 08:15 AM
big cahuna's Avatar
big cahuna
I've had some weird things happen when the magnetic pickup, on the top of the trans picked up some metal whiskers from the oil. The blinkers wouldn't work right, the speedo would jump all over the place, if it didn't spin completely around 360 degrees. And the cruise control wouldn't work. All I did was pull the sensor out and wipe it off, put it back in, and all was good. I did change the trans fluid and never had that issue again.,,
Old Oct 30, 2023 | 08:39 AM
M Oclaf's Avatar
M Oclaf
Happened on my 02 95 twinkie, and it was the sensor. At the time, $65 repair by Sioux City HD as we were west bound. Normally something I would do. It’s easy to access, at least that bike. On a trip, needed the cruise. Speedo was non issue. Good luck!
Old Oct 31, 2023 | 07:15 PM
kevin_n's Avatar
kevin_n
If the turn signals do not self cancel is another indicator that it could be the speed sensor. All functions worked on my wife’s bike, just the speed would jump around on the gauge.
Old Oct 31, 2023 | 08:09 PM
vickers1's Avatar
vickers1
Well I went ahead and ordered the speed sensor. Doesn’t look that bad to install and is the cheapest thing it could be. I’ll update this thread when I get it done.
Old Nov 4, 2023 | 02:08 PM
vickers1's Avatar
vickers1
So far it looks like replacing the speed sensor solved all the problems.
TedMan
EVO
Aug 21, 2022 10:50 AM
60DRB
Jun 15, 2022 01:02 PM
BiggestDawg
Aug 21, 2012 11:46 AM
mccstevie
Aug 13, 2012 10:56 PM
fxdx-fly-by
Aug 5, 2011 06:06 PM
