Boom box
Old Dec 13, 2023 | 02:34 PM
novak6931's Avatar
novak6931
Stage II
Default Boom box
I have a 2022 ultra limited with Apple play. I do not have a WHIM. I have wired headsets, a Aokus Apple play jumper, Cplay2air car play adapter and an iPhone 10. What kind of problems can I expect from Apple play and my intercom system?
Old Dec 13, 2023 | 02:43 PM
David Crowell's Avatar
David Crowell
Maybe none. You don't need the jumper if you use a wired headset.
As far as the wireless CarPlay adapter, it may work. I bought a different one, and although it worked once, it caused a howling in the intercom.
I've since ditched wireless CarPlay and bought a WHIM and two HD-branded Sena 50s headsets. Life is good.
Old Dec 13, 2023 | 02:54 PM
novak6931's Avatar
novak6931
Stage II
Default Boom box
Thanks for the info. I’ve already tried the wireless Sena 10S route. The volume on the headset was loud enough for me. I had a couple Sena Freewire that I used in place of the WHIM. I ditched it and went back to wires.
Old Dec 13, 2023 | 05:20 PM
Ssitruc's Avatar
Ssitruc
I think you may have issue when using your wired headsets when you have the jumper installed... The jumper is there to "trick" the bike into thinking you have a headset plugged in, if you're using a wired headset you do not need the jumper, and it will all work together with your wireless module. I do not use the jumper (I have the ability to do the old software hack) but otherwise the same setup as you. I would think you'd basically have an open mic issue when you plug your headsets in while you have the jumper in place, but that is just a guess because I haven't actually used a jumper.
If you do have an issue, try this "plug jumper", then its easy to take out for those times that you do want to use a headset.
https://logsdonaudio.com/cables/harl...dset-connector
Old Dec 14, 2023 | 01:39 PM
skratch's Avatar
skratch
I don’t believe that you can use the jumper and the wired together. Doesn’t the wiring harness for the comms plug into the same plug as the jumper would?
Old Dec 14, 2023 | 02:14 PM
Ssitruc's Avatar
Ssitruc
Thats what I thought...
Stgo
Jul 27, 2021 12:12 PM
peteknok06
Audio Systems
Sep 15, 2018 04:51 PM
RoyB
Jul 5, 2018 07:20 PM
raisinbrann
Oct 17, 2016 03:54 PM
yorgo
Dec 1, 2010 07:46 AM
