Sena Headset Issue
Old Jan 19, 2024 | 04:28 PM
trawler888's Avatar
trawler888
Stage III
Default Sena Headset Issue
I have a 2022 Road Glide Limited with dealer installed WHIM.
I have a HD branded Sena 50S that is blue-toothed to the motorcycle with headset installed in modular helmet.
When riding I can hear a momentary high pitched hum out of the right ear speaker when the brakes are applied. The hum lasts only a second and then is gone. A phone does not need to be connected to the bike,.
Most noticeable when the front brake is applied with some force. Does not happen when the bike is stationary in neutral. Bike must be in gear. I have noticed that when stationary but in gear the "hum" seems to heard around the time the hill hold light comes on. WHen moving hill hold does not need to be engaged.
Coincidentally, I have a Honda goldwing that I use the same helmet and SENA and there is no "hum". I have an idea of what could be going on but want to hear from other fellow riders.
Old Jan 19, 2024 | 05:05 PM
Rains2much's Avatar
Rains2much
Long shot but gonna guess Voltage regulator or Stator are starting to go.
Old Jan 20, 2024 | 12:02 PM
VA_Larry's Avatar
VA_Larry
It sounds like an electrical interference issue. You may get some answers from the HD help line.
To clarify, when you say the headset is Bluetooth connected to the radio unit. Did you make the connection from within the WHIM menu choice on the radio? Some people have reported issues when they try to use the Bluetooth menu item and connect the headset. Also the headset should not be connected to the radio and a cell phone at the same time. This will confuse which device tries to answer a call. Connect the headset to the radio and the radio to the phone is the preferred method. Just a few thoughts to check.
Old Jan 20, 2024 | 05:56 PM
StoneTrekker's Avatar
StoneTrekker
I actually experienced this too. Somewhere along the way it stopped. Mysterious. No problems of any kind with the bike before or since.
Old Jan 28, 2024 | 09:19 AM
trawler888's Avatar
trawler888
Stage III
The headset is connected to the bike by pairing with the WHIM and following provided instructions. A phone does not need to be connected for the humming noise to be heard. I do not bluetooth my phone to the WHIM or bike. When I do connect the phone I turn off phone bluetooth and hardwire directly to the bike using the USB2 port
Old Jan 29, 2024 | 07:27 AM
VA_Larry's Avatar
VA_Larry
Can you have a fellow rider try to connect their headset to the bike instead o& yours? If they have the audio issue then your device is probably good. Conversely connect your headset to their bike. This might be a quick way to determine is the issue is in your headset or the bike.
Tanker2
2014-2024 Touring Models
13
Jan 20, 2024 02:37 PM
Ibmatt2u
Milwaukee Eight (M8)
28
Dec 5, 2020 10:18 PM
godzilla1964
Jun 11, 2019 06:04 AM
Chrisbu
28
Apr 28, 2015 05:44 PM
nunez8853
Aug 8, 2012 10:08 PM
