Ultra Limited Engine light 'on'
Old Jan 26, 2024 | 08:34 PM
Rounders's Avatar
Rounders
Originally Posted by 702
I would have removed the battery to charge it too. Using a tender, if it worked, would take a while. A good charger can recover a dead battery in a couple hours.
use.
The bike was outside so maybe he had no place to get power.
Typically better to slow charge small batteries. How much it matters I don't know . The battery after a week was probably low not dead. But I don't know
.might be low voltage code and he needs enough starts or miles for it to clear.
Hold trip button in and turn bike on to pull codes. If I am remembering wrong, just Google it.
Old Jan 27, 2024 | 07:28 AM
touchdown's Avatar
touchdown
When I read post like this, I am thinking why not just take the bike to the dealer you got it from. After all its a new bike still under warranty.
Old Jan 27, 2024 | 07:33 AM
Rounders's Avatar
Rounders
Maybe it is a long way?
maybe if it is low battery they will charge him?
Old Jan 27, 2024 | 07:34 AM
702's Avatar
702
Originally Posted by touchdown
When I read post like this, I am thinking why not just take the bike to the dealer you got it from. After all it's a new bike still under warranty.
If he killed the battery, not covered.
Old Jan 27, 2024 | 07:54 AM
Rounders's Avatar
Rounders
I have had low battery alarms when volt reg not putting out good. I was around 10 volts.
Code will probably clear. If it is an active code it will stay up I believe. If old code just flash at start up and go away.
He charged it and bike started. Life is probably good.
Old Jan 27, 2024 | 08:07 AM
touchdown's Avatar
touchdown
Maybe its a bad battery needs to be checked. The OP lived in NC don't get that cold there.
Old Jan 27, 2024 | 08:22 AM
Rounders's Avatar
Rounders
I would think it could handle below freezing for a week, but with new electronics maybe not. Especially if cold when tried to start.
I dont tender for only a week, or at all. But up here when below freezing ridings is over due to salt
I say charge it. If it does again bring battery in for warranty.
Battery will have prorated warranty
Old Jan 27, 2024 | 08:23 AM
Rounders's Avatar
Rounders
How do they know why it died? Battery has warranty
Old Jan 27, 2024 | 08:25 AM
702's Avatar
702
Perhaps, but I would do what he did because taking it to the dealer is a time suck. It's not hard to pull the battery and charge it, unfortunately he didn't follow the proper procedure and now has a CEL. My money says to clear the code and all is good again.
Old Jan 27, 2024 | 08:38 AM
Rounders's Avatar
Rounders
Cold didn't hurt the battery, the bike was just hard to start in cold , and battery discharged some.
My 4 Wheeler sits for a month at 10 degrees I charge before using.
He did nothing wrong. Life is probably good now. If dies again on shorter interval I would then bring in for warranty check
A week of zero is not hurting a battery. This guy was around freezing.
I leave batteries in machine untendered at -15. Charge before use if it has been to long . Guy did nothing bad.
