A friend has a Road King that has a miss in low gear only. All of the suggestions such as; bad gas, faulty ignition coil, bad spark plugs, plugged fuel filter, bad injectors are all eliminated in second gear. Any logical suggestions?
What rpm is the miss. Miss fires tend to occur at upper rpm and load range.
Interestingly my friend brought his Sporty to me and ask me what I thought was causing it to miss in first. Years back.
It wasn't missing. His drive cog belt and pulleys were so worn, it was slipping. Old Sporty with the AMF logo on the tank. Had over 100,000 on it then. Had it since new.
Still his favorite bike.
If it's a FI, and really missing, there should be codes.
Certain touring models of certain years had an issue of broken forward cylinder injector wire harness due to repeated flexing of the harness. Could it be the engine flexes just enough on take off to pull on the harness causing a misfire? It's easy and inexpensive to check. Push and pull on the forward injector's wire harness with the bike idling. If this induces the misfire you may have found the problem. Just a thought...
My 16 ultra was the front coil wire rubbing on the tank, wore a spot right thru.
But that doesn't necessarily explain only missing in first gear... except... The engine tends to shake the most in the lower gear, so it could be a miss issue due to an intermittent electrical cause, that is exacerbated by the engine shaking, and disappears when it smooths out at higher rpm and higher gears...
Here is what to look for on the front spark plug wiring chafing issue...
