Thanks for your advice. I will check the battery first and the connections, especially ground. The last thing I want to do is install a new starter but I know my bike is pretty old and unless the previous owner rebuilt the current starter it looks original so it has lasted as much as one can possibly expect.
It starts slower after 5 miles ride makes me think battery. I once rode for a 14 miles and whole bunch of starts off just battery. Charge it, take off charger, then let it sit for a day, and see if it starts
Yes, after an all night charge the bike starts right up. It has always started with a sort of sluggish sound but it always turns enough to start the bike. If I then take it for a ride to the store maybe 5 miles away at around 50 mph and turn it off, 5 minutes later when I return the bike starts but it sounds sluggish as if it was struggling to turn. I figure that after riding it for that much the battery should not be weak at all. I'll try all the suggestions posted here which are all good. I'd hate to think I need to replace a starter because of the cost but I'm thinking that may be the problem. It is an old bike after all.
Thanks for your advice!
Takes at least 20 minutes of riding with the charging system feeding the battery @ 14 VDC +/- for the battery to recover from starting as it takes a lot of amperage to the move the starter when starting.
What if any aftermarket electrical accessories are on the bike? If a lot of electrical load, it will take even longer for the battery to recover.
Check to see if your charging system is putting out 14 or so VDC when the RPMs are at 2000. A Volt Ohm Meter (VOM) is your friend
nd
But a battery has many starts in it. So he should be able to start a bunch of times, ride 5 miles, and start again. Yes the battery will not be charged 100%, but it should start just fine.
Agreed.
Something is amiss either with the wire connections or the starter, maybe that it is dragging, not aligned correctly or just wore out (brushes or armature). Like stated if he is getting 14 + VDC at 2000 rpm or higher, then I would look at the starter.
OP did not state how many miles on the bike so it is unknown how many start events it had gone through, knowing the mileage might give an indication of start events (rough estimate).
May have corrosion inside the wire insulation that limits volt/amperage transfer. Removing the cable and bending it a bit will tell you if it is corroded as it will feel stiff and not flexible like a good cable.
I'd wonder about the battery. Maybe sitting on a tender all the time is hiding a bad battery. Simple enough. Charge over night. Then leave off tender for a day. Could disconnect battery to eliminate any possibility of parasite draw, but don't need too.
Yes there are better was to test, but sometimes you are just busy.
The bike is pretty stock from factory. I don't even have the radio anymore, I disconnected it years ago. There are speakers still connected on top of each bag but the wires lead nowhere. I will double check tomorrow to be sure. I will also check the tender to see how much is putting out.
I just bought the battery on Amazon this past December. It is a 310 CCA battery. It might be cheap but the one the bike had was even weaker and now it still behaves the same way. The bike has been sitting for a year waiting for me, surgery!
The bike has 45K. I will check the battery in the morning after an all night charge and see were it stands. I'd hate to think I have to replace the starter because I'm sure it's expensive but I can't rely on her not starting anytime I take her out.
