Hi all, 13 RG, due to medical reasons unable to ride since July 23.
. started it up several times and got to operating temp as best I could given the circumstances.
Not started since December 2023, so....
Should I change the fluids cold ( hoping by March or should it be operating temp?
Just concerned about moisture in the fluids.
Always garaged and not colder than 35 degrees F.
Thanks all, hoping to be back on the road by June.
Hope your medical condition is better and that you are feeling better. I would not start it and just let it idle. I would wait until you can get it out and ride for a good distance to get everything up to operating temps....15-20 miles. Then do a 3-hole change. Then check things out and enjoy.
I don't think sitting for a year has hurt it. I would be more concerned with when the fluids were last changed.
about 500 miles before me being sidelined. All 3.
Not one of those to start- run for 10 minutesm "just to hear it" guys.
don't think moisture would be an issue.
just the 1st time my machine sat idle this long.
@1sparky not trying to hijack your thread, but I have been curious about the same type of issue. I have a 2022 RKS bought brand new and I have clocked less than 100 miles. Between cancer treatments and COVID pneumonia it has kicked my butt. I have started it up in the garage and let it run for about 10 minutes on occasion. In my mind, the fluids should all be good, but what would the consensus be? In March, I have to take it to the dealer for the annual inspection and was thinking about doing a fluid change then, just to be safe.
Its been posted several times amongst these pages but 10-minute startups are not good at all for your ride. Especially with colder temperatures - the bike cant reach full operating temp and burn moisture off within the cold engine interior surfaces. Its best to wait until you can actually ride at least 25-30 minutes. Starting for 10-minutes only will form even more moisture and condense even further - simply complicating things. Now youve introduced potential corrosion on engine surfaces.
Best practice is to wait it out.
More importantly though, glad youll be able to ride once again and enjoy the New England backroads. Go north and have a blast up there. 😉. 🤜🏼
Reason: Addition
I don't know the answer to your question, so I won't pretend I do. But, if it were me I would ride it for a couple of hours and then change all fluids. Here's where my head is with why. It has sat for a long time. There are carbon steel moving parts everywhere that oil touches. That steel is likely to have surface rust on it. Everywhere. For that reason, iI would run it - get it hot - let the oil scrub off that rust and other contaminants, then drain while hot. If you change it now, and cold, all that rust will still be there with fresh new oil. Just something for you to think about.
Kevin Baxter in youtube has two videos on his channel that explains and shows video of an engine with rust on the internal parts from starting the engine while in storage, I recommend you view them.
I wouldn't worry about it,any moisture would burn off pretty quickly.
I'd just ride it then check it after a few hundred miles but if you're worried about it change it again.
Living in a Northern state in the mountains my bikes usually sit from November until March or April without being started,I still just change oil at 5K intervals.
Of course it's garaged and on a battery tender,I might change the battery this year before we take a long vacation ride just because it's the original from 2019.
I put 200,000 miles on my last bike and it was never an issue,28,000 on this one so far.
