Foot pegs keep falling down
Old Mar 4, 2024 | 07:39 AM
Greg18SG's Avatar
Greg18SG
6th Gear
Default Foot pegs keep falling down
2018 FLHX - passenger pegs keep dropping.
Can’t find any screws to tighten them up.
suggestions other than replacement?
Thanks in advance.
Old Mar 4, 2024 | 07:47 AM
HarleyBob52's Avatar
HarleyBob52
Might need new foot peg spring washers, if yours has them.. https://www.jpcycles.com/product/jp-...ku_id=10237319
Old Mar 4, 2024 | 07:58 AM
dbarbee's Avatar
dbarbee
There should be a springplate (Part 14 on the diagram below) on the pivot pin between the peg and the mount. It may be missing or it may be flattened out and not providing enough resistance.
Floorboards have a small spring and ball bearing in the mount that engages detents in the floorboard.
Old Mar 4, 2024 | 08:18 AM
Rob175's Avatar
Rob175
Easy home fix.....dental floss tightly forced in and wrapped around the small gap next to the pivot bolt and tied off. Makes it slightly harder to raise and lower the pegs. No more falling down, Worked for me.
Old Mar 4, 2024 | 08:23 AM
uncle kebo's Avatar
uncle kebo
If the pegs are replacements, I quarentee the washer/shim/whatever theyre called either were not put back or are installed incorrect. Ask me how I know....
Old Mar 4, 2024 | 08:54 AM
hattitude's Avatar
hattitude
Interesting, when did the MoCo switch to a pivot pin w/retaining ring instead of the old reliable bolt & nut....??? Doesn't seem like a step forward to me... Gotta be a cost thing...
I never had an issue with the old style bolt/nut combo which is on all the bikes I currently own. Even when the spring washer loses it's spring, you can always snug down the nut to get the proper tension for the pegs to stay up.
OP, maybe you could convert that pivot pin back to a bolt/washer combo and not need to mess with new spring washers or dental floss, that is if HD didn't change from the standard foot peg mount hole size...
Look at these...
https://www.jpcycles.com/product/col...ku_id=10224577
Old Mar 4, 2024 | 09:02 AM
NoRegerts's Avatar
NoRegerts
I don't have an answer, other than to say my 2011 has the pin and clip combo too.
As far as your pegs, falling. The flat spring washer can be removed and bent again to provide more tension. That worked for me and was free.
Old Mar 4, 2024 | 09:07 AM
Harley_ish's Avatar
Harley_ish
... and not need to mess ... with ... dental floss ...
Ah C'mon. You're No Fun
Bungee cord?
Old Mar 4, 2024 | 09:12 AM
hattitude's Avatar
hattitude
I'd be embarrassed to report the number of fixes I have used that contained bailing wire and/or duct tape.... but that was many, many years ago...
While dental floss is ingenious... I have shied away from such repairs in my old age...
Unless stuck on the side of the road.... then nothing is off limits..
izhd
Sep 27, 2014 07:45 AM
SCPowerstrokecowgirl
Mar 28, 2013 11:31 AM
Demolitionman
Jul 13, 2011 02:42 PM
1flhtk4me
Oct 2, 2010 08:18 AM
NEONNIGHT34609
Aug 9, 2006 07:43 PM
