Saddlebag latch Inserts
Old Aug 29, 2007 | 09:26 PM
Colorado Ultra's Avatar
Colorado Ultra
Default Saddlebag latch Inserts
Just a quick question. Has anybody ever installed the Drag Specialties (Hotop) Saddlebag latch inserts? It's to take the place of the red reflector, how does the red reflector come off? I tried the nut at the front and that didn't loosen anything..Any ideas or suggestions..Thanks in advance, Steve
Old Aug 29, 2007 | 09:33 PM
dawg's Avatar
dawg
Default RE: Saddlebag latch Inserts
The reflectors are stuck on with double sided tape. They are a pain to take off, but do pop right off.
Old Aug 29, 2007 | 09:37 PM
Colorado Ultra
Well, that ought to be fun....Maybe I can run some floss orfishing linebehind them to loosen them. Or just bite the bullet and get the reall cool ones.. Hmmmm, Steve
Old Aug 30, 2007 | 06:15 AM
kurtlange's Avatar
kurtlange
warm the reflector up w/ a heat gun/blowdryer and pry it out. i used a screwdriver to break the reflector in the middle and pried up both side from the middle. no scratches on the latch that way...
Old Aug 30, 2007 | 06:24 AM
NCCopBikeRider's Avatar
NCCopBikeRider
Ditto on the heat gun
Ride Em Carry Em
Old Aug 30, 2007 | 07:31 AM
hoz88's Avatar
hoz88
Used a heat gun and the reflectors came right off. I really like the chrome inserts - they clean the latches up. Make sure you clean all of the old glue and crap off before putting the inserts in or you might have problems with them falling out.
Old Aug 30, 2007 | 07:44 AM
Colorado Ultra
Thanks for all of your replies..Sounds like a heat gun ought to do the trick..Ride Free Steve
Old Aug 30, 2007 | 07:47 AM
Colorado Ultra
Maybe just another quick question..where to buy a heat gun? Wal Mart, Lowes home Depot..? Shoot, as hot as my 07 runs, I could just go around the block...Thanks again..Steve
Old Aug 30, 2007 | 07:49 AM
hoz88's Avatar
hoz88
If you don't have a heat gun, use a hair dryer on the high setting. Should be enough to heat the glue for you.
Old Aug 30, 2007 | 07:51 AM
SIM's Avatar
SIM
ORIGINAL: hoz88
+1
