Crank position sensor problems
Old May 7, 2024 | 09:56 AM
Uncle Peepers's Avatar
Uncle Peepers
I think he means he'd like to get this problem solved before he begins a pre-planned major undertaking.
I can't imagine replacing a CPS that's working fine. If you're nervous about its failure, buy one just to have it ready.
Old May 7, 2024 | 12:02 PM
BRKLYN1955's Avatar
BRKLYN1955
Following, where’s Pistol Pete 1911 go to?
Old May 7, 2024 | 01:23 PM
GalvTexGuy's Avatar
GalvTexGuy
He checked in at 1:12 this morning.
Old May 7, 2024 | 02:11 PM
Pistol Pete 1911's Avatar
Pistol Pete 1911
3rd Gear
Originally Posted by Jackie Paper
What was it doing before you replaced the CPS.
PS. Welcome to the HDFORUM. Only as a suggestion, make another new thread over in the newmember welcome area to say hello.
it started backfiring then went into limp mode and then shut down and wouldn't start fortunately I had it in the garage before it completely shut down when I pulled the crank position sensor it was melted and I could see the magnet on the inside. After replacing the sensor and getting it plugged in which is no easy task because of the oil cooler on my bike, it now runs for about 15 seconds and then shuts down again but it will start each time. I figured there was some trash in there from the melted housing on the previous sensor and I can see into the hole a little bit so I grabbed a Q-tip and went fishing and couldn't pull any trash out of the hole.
Old May 7, 2024 | 02:18 PM
Pistol Pete 1911
3rd Gear
Originally Posted by Rounders
The alphabet would help. I am assuming 2006 ultra has i at end of it, but I don't know for sure.
Run for short time makes me think running out of fuel, but no reason to think that. Good point, what was it doing before you replaced?
IMO, bike is 18 years old, I am not afraid to throw parts at it, in the name of maintenance. In the industry I work in, for sake of reliablilty we replace before it fails, before it leaves you waiting for hours for a tow, late for work, or cop talking to you. That said, I have no clue why it would run for 15 seconds. Usually run is run.
FLHTCI 2006, 88 cubic inch twin cam, Arlen Ness big sucker, Freedom true duals, Screaming Eagle clutch package and heavy duty spring. No cam chest upgrades as of yet I figure we would like to solve this non-run issue before we dive into the camshafts.
backfiring and coughing, then limp mode, and then once in the garage and shut off it would not start again
Old May 7, 2024 | 02:20 PM
Pistol Pete 1911
3rd Gear
FLHTCI 2006 Electra Glide Ultra Classic, 88 cubic inch twin cam, Arlen Ness big sucker, Freedom true duals, Screaming Eagle clutch package and heavy duty spring. No cam chest upgrades as of yet I figure we would like to solve this non-run issue before we dive into the camshafts.
Old May 7, 2024 | 04:03 PM
memphisharley's Avatar
memphisharley
remove the sensor...grab a flashlight and look into the hole while someone slowly turns the back wheel while looking to see if anything is on the flywheel.
Old May 7, 2024 | 08:32 PM
Max Headflow's Avatar
Max Headflow
Check fuel pressure.
Old May 7, 2024 | 08:36 PM
hattitude's Avatar
hattitude
Do you have a pic....??
Are you sure it's melted and not "ground down" by the flywheel hitting it....? I hope it wasn't "ground down", but just wanted to ask.....
IMHO, if there was any trash from the melted CPS, it was probably washed down into the bottom of the cases....
Old May 7, 2024 | 08:55 PM
Max Headflow
Yeah. If the CKS is smeared, OP got big problems.
