Kuryakyn adjustable tour pak relocator problem
Old May 8, 2024 | 03:15 PM
BigHoss37's Avatar
BigHoss37
3rd Gear
Default Kuryakyn adjustable tour pak relocator problem
So I have a 2023 RGL and the wife wanted more room so we ordered the relocator. It all went on without any issues but when she gets on the tour pak slides all the way back. Any one have a way to tighten up the locks on this. thanks for the help
Old May 8, 2024 | 03:48 PM
GalvTexGuy's Avatar
GalvTexGuy
First time ever looking at one just now. Instructions?
Old May 8, 2024 | 04:54 PM
MURPHCC1's Avatar
MURPHCC1
Pretty sure its the same type as mine on my 07....underneath there are two levers on each side, they LEVER in and also screw in, dont know what it's called.
BUT, unlatch them, screw them in a few turns and latch them back in. Keep trying to get in it right and tight.
Old May 8, 2024 | 05:45 PM
BigHoss37's Avatar
BigHoss37
3rd Gear
It’s a little different I think there no adjustment that I see the older style shows that adjustment but the newer doesn’t seem to have that but I’ll look again
Old May 8, 2024 | 05:50 PM
MURPHCC1's Avatar
MURPHCC1
Yea there IS an adjustment there on the side, behind the chrome latches right?
https://www.denniskirk.com/kuryakyn/...IaAl9fEALw_wcB
Old May 8, 2024 | 05:52 PM
BigHoss37's Avatar
BigHoss37
3rd Gear
I don’t see anything looks like it just slide or rotate on a stud
Old May 8, 2024 | 06:02 PM
BigHoss37's Avatar
BigHoss37
3rd Gear
So those chrome pop out so you can slide forward and back then the lock into those little hooks but don’t see anything that I can do to tighten or loosen them. The older model looks like it twists this one doesn’t
Old May 9, 2024 | 01:32 PM
MURPHCC1's Avatar
MURPHCC1
Item 18 on the instruction manual says.....
"Disengage the locking levers; adjust the Tour Pak as desired; engage the locking levers."
Are they not holding?
Can you move the seat with them engaged?
Old May 9, 2024 | 10:08 PM
BigHoss37's Avatar
BigHoss37
3rd Gear
Correct they are in locked position and still move
Old May 10, 2024 | 06:51 AM
MURPHCC1's Avatar
MURPHCC1
Is there any tension while your pushing those levers in?
Like it's set up to hold but doesn't.......
call Kuryakyn yet?
