Intermittent sputtering?
Old May 26, 2024 | 07:57 AM
Pix's Avatar
Pix
Default Intermittent sputtering?
2014 Ultra Limited, 85k, at slow speed occasionally bike feels like it is starved for fuel, died once at the light fired right up. after stopping for fuel bike cranked for about 10sec before it fired up. Went thru 3 tanks of gas to make sure it was not bad fuel.
Sprayed TPS cleaner in. erratic idle sometimes bike will go from 900-1400 rpm at the light. Fuel filter changed at 75k. No codes. Any help before I get stranded.
Old May 26, 2024 | 08:23 AM
Germansheperd's Avatar
Germansheperd
When were the plugs and wires last changed?
Old May 26, 2024 | 08:54 AM
Pix's Avatar
Pix
Plugs were changed at 75k, wires were changed by previous owner to Screaming Eagle, not sure when he did that. I bought the bike with 40k mile on it.
Old May 26, 2024 | 10:22 AM
davekp's Avatar
davekp
Fuel filter?
Old May 26, 2024 | 10:57 AM
kojak's Avatar
kojak
Sounds like a fuel problem. Could be anything from a pinhole in the line inside the tank to a fuel filter assembly issue. Fuel filters don’t get clogged in 10k miles of riding but it could be a related issue.
Old May 26, 2024 | 11:54 AM
hardheaded's Avatar
hardheaded
Deleted
Old May 26, 2024 | 03:29 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Pour a shot or two of Seafoam into the tank and continue on! See what happens! Might be something simple, might not. It's always nice to try the easy/less expensive fixes first!
Old May 27, 2024 | 03:46 AM
Dano523's Avatar
Dano523
Ditto with this, and would check to make sure that old Filter O ring was not reused, and why it may be leaking at the assembly there.
Old Jun 4, 2024 | 02:54 PM
Pix's Avatar
Pix
Thought I would update, bike finally threw a code and it was the Engine Temp Sensor.
powhs
Jul 22, 2023 09:05 PM
theshoe
Jul 11, 2012 07:00 AM
kenny ray
Jul 5, 2012 11:55 AM
Hot Rod King
Apr 16, 2011 07:37 AM
Ratrods40
Aug 2, 2010 09:14 AM
