Where is my engine number?
Old Jul 2, 2024 | 10:51 PM
HDan90505's Avatar
HDan90505
Default Where is my engine number?
I need to register this motorcycle and I cannot find the engine number. It’s different from VIN.
1993 Electra Glide Ultra Classic. I already looked by the cylinders and everywhere else that online suggested with no luck.
Old Jul 3, 2024 | 01:53 AM
Dano523's Avatar
Dano523
https://www.sscycle.com/tech-info/engine-serial-lookup
If you do not find a serial number on the primary side of the case below the jugs, then cases where replaced with after market cases/motor.
Also to point out, on rear brake lever of bike side, should be serial number on trans as well.
If all factory bike, the frame/trans/engine serial numbers should match.
Old Jul 3, 2024 | 06:53 AM
Gunnysgt's Avatar
Gunnysgt
Interesting you need an Engine serial number. Is this for registration in CA? Until 1970 Harley embossed the "engine number" on the left side at the base of the cylinders. This number was also the "VIN" since the 17 digit VIN did not exist yet. My Panhead was 52FL1624 for example. I've registered motorcycles in CA when I lived there and do not recall needing and engine number.
Old Jul 3, 2024 | 12:08 PM
hattitude's Avatar
hattitude
Yes, CA puts the engine identification number (EIN) on motorcycle registrations...
Old Jul 3, 2024 | 03:06 PM
memphisharley's Avatar
memphisharley
so what does one have to do if they purchased a used engine.
Old Jul 4, 2024 | 10:44 AM
hattitude's Avatar
hattitude
If you change the engine, you're supposed to visit the DMV. You get the proper forms to amend/change your registration/pink slip, go have CHP (or DMV inspector) verify the new engine number (and that it's not reported stolen), pay the appropriate fee (it IS California, nothing is allowed without a fee), file the paperwork, and your new registration/Pink Slip will reflect the new Engine number.
Old Jul 4, 2024 | 11:09 AM
Dano523's Avatar
Dano523
Yep, all about making sure things are not stolen, and now with cars, they are pulling the vin numbers from the ECM/BCM, in case the car vin on the dash has been replaced with fake one. With bikes now having ECM, only a matter of time until they start doing that with the bikes as well.
Hence to flash a ECM or BCM with manufacturers software, need to use the correct real vin number for the car for the flash to work, SO just can't use a fake vin number that is ether over stamp or changed vin plate to pull that one off.
Old Jul 23, 2024 | 10:50 AM
HDan90505's Avatar
HDan90505
FINALLY FOUND THE ENGINE NUMBER.
It is an Ultima engine, and I found the engine number on the front end of the block, right behind the front tire and below the oil filter.
TA Motorsports
Mar 25, 2026 03:42 PM
cycleman11
EVO
Jun 19, 2022 07:23 AM
jaymotor1977
Welcome Area Only
19
Sep 11, 2021 07:32 PM
Bever
Jun 10, 2016 11:56 PM
ccgobama
Apr 15, 2006 01:50 AM
