EITMS question
Old Jul 6, 2024 | 04:31 PM
Rob175's Avatar
Rob175
Default EITMS question
My question is....When the cooling fan turns ON, does the rear cylinder always shut OFF....or are the two features independent of each other? I ask because, today my fan kicked on BUT the rear cylinder didn't shut down. Outside air temp was 75-80 degrees,
(2015 Ultra Limited w/EITMS "ENABLED"...w/liquid cooled heads)
It's worked fine in the past, but I can recall IF the the rear cylinder ever shut off when the cooling fans came on.
Bike runs great, no limp mode just wondering about the above.
Old Jul 6, 2024 | 04:41 PM
elPrez's Avatar
elPrez
Completely independent
https://serviceinfo.harley-davidson....49400&nid=5671
Old Jul 6, 2024 | 04:50 PM
Rob175's Avatar
Rob175
OK...I just "assumed" that IF the cooling fans kicked ON then the engine should be hot enough to shut down the rear cylinder. I know that , in the past, I recall the rear cylinder cutting out when sitting in hot weather but just can't recall the fans also kicking on at the same time.
Old Jul 6, 2024 | 04:54 PM
gonemad's Avatar
gonemad
EITMS does not engage till the ambient temps reach 80F or above, and you are stopped.
Old Jul 6, 2024 | 05:01 PM
Rob175's Avatar
Rob175
Thanks again!!
Old Jul 7, 2024 | 06:51 AM
BigD48's Avatar
BigD48
Here’s some HD techs explaining the EITMS and also one from Doc Harley.
Old Jul 8, 2024 | 10:35 AM
Rob175's Avatar
Rob175
EXCELLENT...thanks so much.
From what they say, my guess is the ambient temp or coolant temp wasn't high enough to meet the parameters for the rear cylinder to turn off, even IF the cooling fan DID TURN ON.
The system has worked flawlessly in the recent past so I'm assuming all of the parameters weren't met.
Thanks again
johnod
EVO
Jan 14, 2016 06:51 AM
mang0
Exhaust System Topics
Jul 7, 2012 10:39 AM
Bedore
Sep 21, 2010 11:35 PM
stmpulr
Aug 31, 2008 09:20 PM
t150vej
EVO
Jul 31, 2008 09:14 AM
