Starter question?
Old Jul 8, 2024 | 06:47 PM
HD_noobie's Avatar
HD_noobie
Check your battery cables make sure there tight
Old Jul 8, 2024 | 09:53 PM
im's Avatar
im
Originally Posted by REW13
voltage is good in the battery, yes I turned the switch off and turned the key(switch) off.
what is a clutch lock? and where is it?
thank you BTW
Caution with just reading voltage since a battery can have voltage, no reserve and diminished amps.
Alternatively the battery could just have surface voltage and the load just draws down battery.
It is suggested that battery be load tested at an auto shop(many are free) but a digital voltage meter at battery posts will give you a general idea.
What are your voltage numbers?
Voltage at rest with everything OFF? This one gives you an idea if battery is charged.
Voltage while cranking? This one gives you an idea if battery has enough juice to start.
Voltage at idle and then high idle? This one gives you an idea of how bike is charging at idle(stuck in traffic) and then high idle (rolling down the road).
Too many people replace a battery and never check charging system with this simple test.
How old is the battery?
Regarding clutch switch/interlock /safety-Very similar to newer stick shift cars.
At one point the manufacturer started to put a lock-out safety switch located between clutch lever and clamp.
Very similar but different to switch at front brake lever.
Switch requires bike to be in neutral or have the clutch pulled-in for bike to crank/start.
Does your bike crank with clutch pulled in but bike in gear? or only in neutral?
I do not know if your year had the switch.
*If it was my bike, I would start with battery testing at home with a digital voltage meter.
Then I would review the FOUR ends 4 of battery cables.
FL54
Shovelhead
44
Jan 24, 2018 08:31 AM
dwoodlives
Feb 26, 2016 04:17 PM
Rabbito
Shovelhead
11
Jul 16, 2014 06:48 PM
Tramontin
Shovelhead
May 7, 2014 07:00 AM
VTwinJaxFL
11
Nov 13, 2010 07:32 PM
