2007 Road Glide Question?
Old Sep 1, 2007 | 04:36 PM
hawkyou's Avatar
hawkyou
Default 2007 Road Glide Question?
I have a 2007 HD Road Glide and I am installing the lower fairings tonight. The instructions are telling me to move the clutch cable from the rear of the highway bar to the front. Does this really need to be done? I still can't figure out why? Anyways, any input would help.
Thanks!
Will be posting pics soon.
Old Sep 1, 2007 | 05:17 PM
hawkyou's Avatar
hawkyou
Default RE: 2007 Road Glide Question?
bump
Old Sep 1, 2007 | 07:03 PM
Thundercloud's Avatar
Thundercloud
No, You do not need to move the cable. I know it said that when I did them on my 05 RG and it is not necessary unless it does happen to be routed in your way, but if it is routed like they do from the factory you should be fine.
Ride Safe!!!!!!!!
[IMG]local://upfiles/4934/3C2E2BF7CBEF41FCAAED7062F2BB26ED.jpg[/IMG]
Old Sep 1, 2007 | 07:23 PM
marvincbr's Avatar
marvincbr
Mine goes down the fork tube, attached with $.50 clamp to keep it from slapping the inside of the fairing, and in front of the engine guard/highway bar. Mine was also changed to the braided one, don't remember position of the stock one.
Old Sep 1, 2007 | 09:18 PM
Pilgrim's Avatar
Pilgrim
Semi-hijack now.
I just retired the 1984 FXRT that I've ridden since new (pic at http://www.wildwestcycle.com/f_bigtank.html/), onto an '07 Road Glide.
The RT is carrying the stock fairing, and the lowers that were available for a while. They are a good combo. The cylinder head temp gauge I used to run told me that the lowers knocked 15 to 20 degrees off cylinder head temps (and thus helped oil temps) when they were installed. No guesses; that's data. They were designed in a wind tunnel by Harley back when they cared about such small things, and it shows.
The pics I've seen of the lowers for the RG fairing show a similar profile to the FXRT's, but I can't really tell how close they are. There are no real ones around here to look at. Do the RG lowers duct air to the heads, or not?
And do they mount flush against the bottom of the fairing like the ones on the FXRT do? Or do they leave a gap that runs air across your knees, like the lowers that mount with the batwind fairing?
Final question: the fairing on the Road Glide is obviously grandson to the one on the early Tour Glide (FLTC - 1982 to 1986, more or less). Does anyone know whether or not the lowers that went with that old fairing will mount up to the current one?
Pilgrim
bluce
Electrical/Lighting/Alarm
Mar 26, 2014 12:13 PM
ctanders
Dyna Parts
14
Sep 11, 2011 06:58 AM
waffler
Motorcycles For Sale
Oct 9, 2008 04:24 PM
oilhog
Mar 3, 2008 07:13 AM
choppers4life1
Nov 7, 2007 08:21 PM
