ThunderMax Question...
Old Sep 2, 2007 | 08:40 PM
bpterb's Avatar
bpterb
Default ThunderMax Question...
Searched and not finding my answer. Can I and install the ThunderMax with autoune on my 2006 streetglide since the stock pipes do not have O2 sensors? I also am fixen to order the VanceHines true duals but they also will not have the O2 sensorscorrect?
Old Sep 2, 2007 | 08:50 PM
sleepyjim's Avatar
sleepyjim
Default RE: ThunderMax Question...
Yes but ya need to get the bungs installed, simple, matter of drill hole and weld bungs in place................
Old Sep 2, 2007 | 09:00 PM
bpterb's Avatar
bpterb
Do you know if I am able to order the dresser duals from Vance & Hines with the sensor outlets in the header pipes to fit my 06? Or do I have to also installthe O2 sensor outlets in the new header pipes?
Old Sep 2, 2007 | 09:03 PM
Abnmarine's Avatar
Abnmarine
Not sure on those pipes but my Fatcats came with bungs already installed.
Old Sep 3, 2007 | 08:02 AM
bigdaddy64's Avatar
bigdaddy64
bpterb, check with rinehart to see if the true duals for an '07 will fit your '06. I swapped the pipes along with tmax install. if not you'll have to weld in the bungs. good luck
rockajet1
Feb 28, 2013 06:55 PM
Dannicus131
Nov 30, 2012 10:39 PM
ubreal
Dec 10, 2008 10:33 PM
ragasadr
Exhaust System Topics
Mar 27, 2008 12:12 PM
Undefined
Jul 14, 2007 12:06 PM
