Drilling out baffles
Old Sep 3, 2007 | 01:18 PM
jmac997's Avatar
jmac997
6th Gear
Default RE: Drilling out baffles
ORIGINAL: wldbill
Punched out stock mufflers, IMHO, sound like crap and I think you'll regret ruining them.
Yup. I ran a 5/8" bit through and through. Changed the sound allright. Sounds like crap. The next day I found a used set of Rinehart true duals on ebay for $300 bucks and some change. Fedex is taking the scenic route with them, but I should get them tomorrow.
Don't do it.
I don't even have my stock pipes to hang in the rafters now.
Old Sep 3, 2007 | 01:38 PM
txphoneman's Avatar
txphoneman
I popped out the quater sized pluge from my 05 Heritage. It was a choke control. They sounded great afterwords. However you have to be careful doing it to an enjected engine. The engine would need to be recalibrated. Not worth the trouble. Anyway I like the way my ultra I have now is quiet as I can hear the radio. FOOY IT who needs loud pipes!!
Old Sep 3, 2007 | 03:27 PM
sugarbear's Avatar
sugarbear
nccopbikerider, this is where I got my information
Maybe I'm missing some pertinent bit of info since I'm on a dial-up connection and have opted for a simplified forum presentation. I say that because nobody seems to have answered your question. I'll answer it with "the left and right mufflers are completely different from each other internally on the '07s".
The right muffler has a series of chambers or at least a convoluted path into and out of whatever's inside. (To my knowledge the '07s do not have a catalyst system.)
The left one is basically one big hollow resonating chamber with a single tube at the rear end. The tube has a few holes in it. That's it.
Don't try to use the 2007 touring mufflers on a set of true dual head-pipes.
If you plan to just put aftermarket mufflers on and keep both your O2 sensors in service it would probably be a good idea to get a smaller baffle for the left side muffler than what's in the right. If you aren't going to use the sensors it doesn't matter.
Do you not think that is true?
Old Sep 3, 2007 | 04:27 PM
jammerx's Avatar
jammerx
ORIGINAL: jmac997
ORIGINAL: wldbill
Don't do it.
DITTO HERE.... Cut the "freeze out plugs" out and they sounded like chit.Bought 2 freeze out plugs and put them back in...
Old Sep 3, 2007 | 04:56 PM
NCCopBikeRider's Avatar
NCCopBikeRider
Bear:
Thanks for the response.
The origional poster (aldabob) wanted to know if anyone had drilled out stock mufflers.
I stated the the Fullsac conversion worked well with Stock Mufflers.
You responded with "You can't use the fullsac on stock pipes "
Would like to know how you came up with that statement.
Many many forum members use Fullsacs with stock mufflers with positive results.
I made no statement about drilling/knocking out baffles.
Sorry for any confusion
Ride Em Carry Em
Old Sep 3, 2007 | 05:19 PM
sugarbear's Avatar
sugarbear
nc, sent you a pm
Old Sep 3, 2007 | 05:21 PM
glens's Avatar
glens
I didn't invent the all the wording but recognize it put together like that as something I did come up with. He probably got that information largely from one or more of my posts.
You can use the Fullsac dual conversion with stock mufflers so long as they are versions prior to '07. The '07 mufflers are completely different animals from one another left-to-right. The description given is correct. The left muffler is not so much a muffler as a vented resonating chamber. It will flow some and I guess if you were to use one on each side you might have a measure of success but certainly not like with one of what's on the right on each side.
I guess I'd take exception to the statement, technically, that you can't use the conversion with the stock pipes. It's the mufflers which prohibit success. The conversion kit is specifically for the pipes and will do what it's supposed to do in that regard but if you try to use the '07-and-up (so far) stock mufflers you will be greatly disappointed.
Old Sep 3, 2007 | 05:27 PM
sugarbear's Avatar
sugarbear
Thanks glen I had to go back and find the answer you gave me. I guess it is confusing with the 07 being different. How is the weather there?
Old Sep 3, 2007 | 05:28 PM
sugarbear's Avatar
sugarbear
sorry aldabob didn't mean to hijack your post
Old Sep 3, 2007 | 09:12 PM
Snobal's Avatar
Snobal
ORIGINAL: aldabob
Has anyone ever drilled out there stock baffles.I don't have the money to change my exhaust and want the sound.Does this work and will it screw up my bike.It's a 06'road king
Do not screw with your stock mufflers! Keep them for when its time to sell the bike cause it won't be long before you must havethem for annual inspections..... You can bet on the feds forcing the states to "smog & noise" check bikes within the next few years.
If ya can get a set of '05 or earlier bagger mufflers,drill a 3/8" hole through the 1/8" hole in the front and rear baffle in the right muffler. You will need a drill extention for this but it works just fine. You will get a little more sound and it won't screw up your performance.
---OR----
Drop by your friendly HD Dealer and ask if they will give ya a set of stock"take off" mufflers from a '07 or '08 bagger. Most dealerstrash the take-off parts and will give them to ya if they know you.
You may find that these will produce all the noise you want. I got a set for my '06 Ultra and they sound deeper, with a nice rumble since theleft muffler is basically hollow.
With either the drilled out '05 mufflers, or the '07 and later mufflers, your bike is going to run cooler and sound better than it does with those dumb-a$$ cat mufflers that came on the '06's.
JMHO
