Tire Question...
Old Sep 3, 2007 | 10:04 AM
Dalej's Avatar
Dalej
Default Tire Question...
I was wondering if I can use a rear tire on the front. It looks like the wheels are the same, so didn't know why there is two different size tires. 04 FLHRC
Old Sep 3, 2007 | 10:20 AM
rwskinner's Avatar
rwskinner
Default RE: Tire Question...
Others may have different opinions although I know some that done it.
I think it could make for a wild ride especially in curvesor in the rain. Generally I *think* the tires are marked for Front or Rear service because of the tread patterns, possibly compound, and contours.
I would think a rear drive tire would most likely have a stiffer side wall to transmit torque and most likely wouldn't be the best for biting the road in turns.
Old Sep 3, 2007 | 10:27 AM
Dalej's Avatar
Dalej
It just bothers me not to know things. I thought that a rear tire on the front would be better since it a little wider, hence better control.
Old Sep 3, 2007 | 11:56 AM
dstockton's Avatar
dstockton
The rear has ahigher load rating and is a stiffer tire. I'm with skinner here, I think it would make for a less comfortable, possibly even more dangerous ride. Motorcyle tires are not like car tires and have completely different jobs to do on the front vs the back. Stick with what the tire manufacturers and HD says on this one. Tires are not something to experiment with.
Old Sep 3, 2007 | 12:49 PM
MACK's Avatar
MACK
Simply, if you use a rear tire on the front you will have a flat the first time you corner hard from the tire hitting the fender mount bolts. You will not be able to tread water at all in the curves and you will experience much less traction when braking keeping in mind that 70% of your braking is on the front. If you are looking for a quick suicide act out of this life that will do it.
Iron lHorse
Feb 23, 2011 06:28 AM
DaSham58
Jul 22, 2010 08:43 PM
DanielBoone
Jun 13, 2010 10:05 AM
wbusch
Mar 23, 2009 11:30 PM
FLTR2008TRIKE
Jan 25, 2009 02:40 PM
