2004 FLHTC--sputtering on acceleration
Old Oct 26, 2024 | 09:37 AM
Uncle Peepers's Avatar
Uncle Peepers
Default 2004 FLHTC--sputtering on acceleration
As the title says, I have a friend with a 2004 FLHTC; recently, when rolling on the throttle, he experiences sputtering and hesitation, but only on an intermittent basis. Otherwise, the bike runs fine.
Having experienced these symptoms on my own bikes in the past, my guess is it's a bad fuel pressure regulator which will eventually get worse.
Any thoughts?
Old Oct 26, 2024 | 10:01 AM
Musician's Avatar
Musician
Might be that, or possibly a gas filter reaching its end.
Old Oct 27, 2024 | 06:45 AM
LazySundays's Avatar
LazySundays
On my 03 it was the wires to the front injector getting pulled when accelerating. It eventually turned into a full misfire. There was no check engine light until the front cylinder stopped firing completely.
Feel along the front injector wires close to the injector and check for a narrow spot in the wire where the copper is broken inside the insulation. You can also try wiggling and gently pulling the wires with the engine running to se if the cylinder cuts out.
You can buy a pigtail at Napa that will let you extend the wires a tiny bit so they don't get pulled anymore.
terry wright
Jul 13, 2011 07:18 PM
itsmf
Dec 24, 2010 11:20 AM
Danowert
Motorcycles For Sale
Aug 29, 2008 11:42 AM
PastorTom
Aug 9, 2008 07:56 PM
HDF Tech
General Topics/Tech Tips
Dec 24, 2005 01:46 PM
