Fairing supports
Old Dec 15, 2024 | 03:28 AM
2011BlackGlide's Avatar
2011BlackGlide
Default Fairing supports
Bought an older Ultra and found someone had removed the fairing supports that run from the speakers to the up/down supports. I assume this was done to accommodate the larger speakers. Is this something I should be concerned about? Should I worry about finding a way to replace them?
Old Dec 15, 2024 | 06:55 AM
MURPHCC1's Avatar
MURPHCC1
What year?
And yes replace them, otherwise you can get some movement of the fairing you wont want.
They are a known weak item in the first place for certain years and there a few aftermarket ones that are made of stronger plastic of metal.
Old Dec 15, 2024 | 07:52 AM
Weeboy1's Avatar
Weeboy1
They were prone to cracking and breaking in earlier models (under 08 I believe) they do serve an important function in maintaining the stability of that inner fairing. Especially if components are added under the hood like amps etc that add weight. Replacements are easily found and easily installed. Original owner likely had them break and didn’t bother replacing or didn’t realize how to incorporate them with new larger speakers.
Old Dec 16, 2024 | 08:22 PM
Mongo1958's Avatar
Mongo1958
I would replace them with an after market brace
EightballRider77
Audio Systems
Jan 31, 2024 11:51 AM
mazman
Jun 13, 2022 07:09 PM
sprint07
Touring Parts
May 16, 2014 10:59 AM
DoubleZ
Apr 19, 2012 07:26 PM
urslo
Apr 1, 2009 04:00 PM
